[gdal-dev] CreateCopy() Not writing ColorInterp Data
Frank Warmerdam
warmerdam at pobox.com
Tue Nov 18 16:39:48 EST 2008
Tom V. wrote:
> Frank, it looks like this:
> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Blue
> Band 2 Block=1024x1024 Type=UInt16, ColorInterp=Green
> Band 3 Block=1024x1024 Type=UInt16, ColorInterp=Red
> Band 4 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
Tom,
The GeoTIFF driver will not default to setting PHOTOMETRIC_RGB for
16bit images. Try passing the PHOTOMETRIC=RGB creation option to the
GTiff driver CreateCopy() method to force use of RGB photometric mode.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
