[gdal-dev] gdal 1.5.3 dependencies on Linux
Frank Warmerdam
warmerdam at pobox.com
Mon Nov 24 11:05:18 EST 2008
Gong, Shawn (Contractor) wrote:
> hi list,
> I am building gdal 1.5.3 on Linux (RHEL).
> I build the dependencies as follows (this was what I used for gdal 1.4.0):
> 1) glib 1.2.10
> 2) gtk+ 1.2.10 # stay with gtk 1.3 now, I plan to upgrade to
> gtk 2 in near future
> 3) Mesa 5.0.2 (Mesalib only, no demo, no glut)
> 4) gtkglarea-1.2.2
> 5) python 2.5.2
> 6) pygtk-0.6.12
> 7) gtk+extra-0.99.17
> 8) python-gtkextra-0.22 # 6), 7) 8) are for gtk 1.3
Shawn,
The above are irrelevant for GDAL - they are OpenEV dependencies.
> 10) proj-4.4.7
> 11) gdal external format libraries
> 11a) zlib-1.2.3
> 11b) jpeg-6b
> 11c) szip-2.1
> 11d) HDF5
> 11e) HDF4
> 12) gdal-1.5.3 (w/ rsat2 driver from 1.6 beta)
The above should generally be fine, though you weren't specific
about versions. You might want to keep an eye on the
http://trac.osgeo.org/gdal/wiki/BuildHints for some details on
HDF4 and HDF5.
> Would someone confirm that the above dependencies are right?
> another question about gcc, I have been using
> /usr/lib/libstdc++.so.5.0.3, is it too old for gdal-1.5.3?
I am not aware of any specific dependencies on a libstdc++ version
in GDAL. Generally the important thing is just to use the regular
versions that is associated with the g++ you are building with and
to avoid mixing or overriding.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
