[gdal-dev] gdal 1.5.3 build error on Linux
Gong, Shawn (Contractor) Shawn.Gong at drdc-rddc.gc.ca
Mon Nov 24 16:12:40 EST 2008
Thanks Frank.
I have tried to build on gdal 1.5.3 (w/o HDF) and overnight stable
branch. I got the same error message. But libgdal.so.1.12.3 was created
in gdal-1.5.3/.libs/
What is the problem?
/bin/sh /home/sgong/dev181/gdal-1.5.3/libtool --mode=compile --tag=CC
gcc -g -O2  -Wall -Wdeclaration-after-statement
-I/home/sgong/dev181/gdal-1.5.3/port
-I/home/sgong/dev181/gdal-1.5.3/gcore
-I/home/sgong/dev181/gdal-1.5.3/alg -I/home/sgong/dev181/gdal-1.5.3/ogr
-I/home/sgong/dev181/gdal-1.5.3/ogr/ogrsf_frmts
-I/home/sgong/dev181/gdal-1.5.3/frmts -DOGR_ENABLED
-I/home/sgong/dev181/gdal-1.5.3/port -I/home/sgong/dev181/dist
-I/home/sgong/dev181/dist/include  -c -o gdalinfo.o gdalinfo.c
libtool: compile:  gcc -g -O2 -Wall -Wdeclaration-after-statement
-I/home/sgong/dev181/dist/include -c gdalinfo.c  -fPIC -DPIC -o
.libs/gdalinfo.o
-I/home/sgong/dev181/dist/include -c gdalinfo.c -o gdalinfo.o >/dev/null
2>&1
/bin/sh /home/sgong/dev181/gdal-1.5.3/libtool --mode=link       g++
gdalinfo.o  \
        /home/sgong/dev181/gdal-1.5.3/libgdal.la -o gdalinfo
libtool: link: g++ gdalinfo.o -o .libs/gdalinfo
/home/sgong/dev181/gdal-1.5.3/.libs/libgdal.so -L/usr/local/lib
-L/home/sgong/dev181/dist/lib -L/home/sgong/dev181/dist -L/usr/lib
-L/usr/kerberos/lib
-L/home/marinier/gcc-4.2.2-build/i686-pc-linux-gnu/libstdc++-v3/src
-L/home/marinier/gcc-4.2.2-build/i686-pc-linux-gnu/libstdc++-v3/src/.lib
s -L/home/marinier/gcc-4.2.2-build/./gcc /usr/local/lib/libexpat.so
/home/sgong/dev181/dist/lib/libhdf5.so
/home/sgong/dev181/dist/lib/libsz.so -lmfhdf -ldf
/usr/local/lib/libsz.so -logdi31 /usr/lib/libjpeg.so -lpq -lrt
/usr/local/lib/libcurl.so -lldap -lssl -lcrypto -lgssapi_krb5 -lkrb5
-lcom_err -lk5crypto -lresolv -ldl -lz /usr/local/lib/libstdc++.so -lm
-lc -lgcc_s -Wl,-rpath -Wl,/home/sgong/dev181/dist/lib -Wl,-rpath
-Wl,/usr/local/lib/usr/bin/ld: warning: libcom_err.so.3, needed by
/usr/lib/libssl.so, may conflict with libcom_err.so.2
/home/sgong/dev181/gdal-1.5.3/.libs/libgdal.so: undefined reference to
`std::__default_alloc_template<true, 0>::allocate(unsigned int)'
`std::__default_alloc_template<true, 0>::_S_free_list'
`std::__default_alloc_template<true, 0>::_Lock::~_Lock()'
`std::__default_alloc_template<true, 0>::_S_force_new'
`std::__default_alloc_template<true, 0>::_Lock::_Lock()'
`std::basic_string<char, std::char_traits<char>, std::allocator<char>
>::_Rep::_S_create(unsigned int, std::allocator<char> const&)'
`std::__default_alloc_template<true, 0>::_S_refill(unsigned int)'
>::_S_empty_rep_storage'
`std::__default_alloc_template<true, 0>::_S_node_allocator_lock'
`std::__default_alloc_template<true, 0>::deallocate(void*, unsigned
int)'
collect2: ld returned 1 exit status
make[1]: *** [gdalinfo] Error 1
make[1]: Leaving directory `/home/sgong/dev181/gdal-1.5.3/apps'
make: *** [apps-target] Error 2
thanks,
Shawn
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: Monday, November 24, 2008 11:05 AM
To: Gong, Shawn (Contractor)
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] gdal 1.5.3 dependencies on Linux
Gong, Shawn (Contractor) wrote:
> hi list,
> I am building gdal 1.5.3 on Linux (RHEL).
> I build the dependencies as follows (this was what I used for gdal
1.4.0):
> 1) glib 1.2.10
> 2) gtk+ 1.2.10           # stay with gtk 1.3 now, I plan to upgrade to
> gtk 2 in near future
> 3) Mesa 5.0.2 (Mesalib only, no demo, no glut)
> 4) gtkglarea-1.2.2
> 5) python 2.5.2
> 6) pygtk-0.6.12
> 7) gtk+extra-0.99.17
> 8) python-gtkextra-0.22    # 6), 7) 8) are for gtk 1.3
Shawn,
The above are irrelevant for GDAL - they are OpenEV dependencies.
> 10) proj-4.4.7
> 11) gdal external format libraries
>  11a) zlib-1.2.3
>  11b) jpeg-6b
>  11c) szip-2.1
>  11d) HDF5
>  11e) HDF4
> 12) gdal-1.5.3 (w/ rsat2 driver from 1.6 beta)
The above should generally be fine, though you weren't specific
about versions.  You might want to keep an eye on the
http://trac.osgeo.org/gdal/wiki/BuildHints for some details on
HDF4 and HDF5.
> Would someone confirm that the above dependencies are right?
> another question about gcc, I have been using
> /usr/lib/libstdc++.so.5.0.3, is it too old for gdal-1.5.3?
I am not aware of any specific dependencies on a libstdc++ version
in GDAL.  Generally the important thing is just to use the regular
versions that is associated with the g++ you are building with and
to avoid mixing or overriding.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
