[gdal-dev] is there a way to rename fields with gdal/ogr 1.5.x?
Tamas Szekeres szekerest at gmail.com
Fri Oct 3 16:26:25 EDT 2008
This option is related to RFC21
(http://trac.osgeo.org/gdal/wiki/rfc21_ogrsqlcast) and only available
in the development version.
The latest FWTools release should contain the related binaries.
Best regards,
Tamas
2008/10/3 Duarte Carreira <DCarreira at edia.pt>:
> Hi all.
> I was trying to convert & rename a shapefile and getting syntax errors with
> the -sql string… So I'm wondering if this is working in 1.5.x or only in
> 1.6dev?
> If it's not working in 1.5 is there any other way to accomplish this in this
> version?
> Thanks,
> Duarte Carreira
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
