[gdal-dev] is there a way to rename fields with gdal/ogr 1.5.x?
Duarte Carreira DCarreira at edia.pt
Mon Oct 6 12:26:14 EDT 2008
Tamas,
Thanks for your reply.
The problem to using the latest FWTools is the missing SDE plugin...
compiling it myself is behond my knowledge. That's why I was hoping for a
workaround with 1.5.x. Do you suppose I could get a compiled copy??
Regards,
Duarte
De: Duarte Carreira [mailto:DCarreira at edia.pt]
Enviada: sexta-feira, 3 de Outubro de 2008 18:21
Para: gdal-dev at lists.osgeo.org
Assunto: [gdal-dev] is there a way to rename fields with gdal/ogr 1.5.x?
Hi all.
I was trying to convert & rename a shapefile and getting syntax errors with the -sql string... So I'm wondering if this is working in 1.5.x or only in 1.6dev?
If it's not working in 1.5 is there any other way to accomplish this in this version?
Thanks,
Duarte Carreira
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081006/e21e2dd0/attachment.html
