[gdal-dev] How do I re-size a BSB (KAP) file?
Christopher Barker Chris.Barker at noaa.gov
Wed Oct 8 17:15:25 EDT 2008
Hi all,
I'm trying to use the GDAL utilities to re-size a NOAA Raster Chart.
They are pretty huge, so I want it at say, 1/4 of the resolution. GDAL
can't write BSB format (patent issues -- arrrgg!), but that's OK, any
reasonable format is fine. I've tried:
gdal_translate -outsize 25%  25% -of GTiff 18474_1.KAP 18474_1_25.tif
This seems to work, I get a tif file that is smaller, and looks right in
a non-geo-referencing image viewer. However, when I open it up in QGIS,
it gets squished. I think the issue is that the tiff is not in the
mercator projection the orginal is in, so the pixels are not square in
lat-long coords.
I also think I see why. If you run gdal info on the KAP file, you get:
Driver: BSB/Maptech BSB Nautical Charts
Files: 18474_1.KAP
Size is 8385, 12764
Coordinate System is `'
GCP Projection = GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG",7030]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG",6326]],PRIMEM["Greenwich",0,AUTHORITY["EPSG",8901]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG",9108]],AXIS["Lat",NORTH],AXIS["Long",EAST],AUTHORITY["EPSG",4326]]
GCP[  0]: Id=GCP_1, Info=
           (514,11759) -> (-122.71125,47.2631666667,0)
GCP[  1]: Id=GCP_2, Info=
           (514,595) -> (-122.71125,47.6648333333,0)
... and a whole bunch more GCPs
It looks like GDAL does not know that it is in a Mercator projection.
Why not? the info is there in the .KAP header.
Is it just a missing feature of the BSB driver?
If so, how hard would it be to add? (I'm not much a C++ programmer)
If it were added, would what I'm trying to do work the way I expect?
Is there a work-around in the mean time?
Here is the relevent part of the KAP header:
CRR/
VER/3.0
BSB/NA=PUGET SOUND SHILSHOLE BAY TO COMMENCEMENT BAY,NU=1679,RA=8385,12764
     DU=254
KNP/SC=40000,GD=NAD83,PR=MERCATOR,PP=47.467,PI=5.000,SP=,SK=0.0000000
     TA=90.0000000,UN=FATHOMS AND FEET,SD=MEAN LOWER LOW
WATER,DX=4.00,DY=4.00
** I think that means:
   SC: scale - 1:40,000
   GDL: datum -- NAD83
   PR: Projection -- mercator
   PP: Projection Parameter -- in this case, it's the latitude of the
given scale(what's this called?)
   PI: ???
   SP: ???
   SK: Skew angle -- 0.0 (I don't know what units that is in...
   TA: ??? -- 90
   UN: depth units -- not relevant for GDAL, though it would be nice if
it got stored somewhere.
   SD: Sounding datum -- see above
   DX: X pixel size -- 4.00 (I think in meters )
   DY: Y pixel size -- 4.00    ""
I think that's enough to get the whole projection, though I think you'd
need at least one GCP to position the file.
Without altering GDAL, can I extract that info from the header, and pass
in a projection to gdal_translate? what would I pass in? How would I
pass it in?
Does GDAL have a policy as to what it does if a file has both full
projection info and GCPS?
-Chris
(I've enclosed the entire header, in case there is missing info from my
above extraction)
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
CRR/
VER/3.0
    DU=254
    TA=90.0000000,UN=FATHOMS AND FEET,SD=MEAN LOWER LOW WATER,DX=4.00,DY=4.00
KNQ/EC=RF,GD=NARC,VC=UNKNOWN,SC=MLLW,PC=MC,P1=UNKNOWN,P2=47.467
    P3=NOT_APPLICABLE,P4=NOT_APPLICABLE,GC=NOT_APPLICABLE,RM=POLYNOMIAL
CED/SE=08,RE=01,ED=10/01/2003
NTM/NE=08.160,ND=09/01/2007,BF=OFF,BD=10/01/2003
ADN0001/USCG;13;06/12/2007;;08/28/2007;
ADN0002/CHS;13;;;06/29/2007;
ADN0003/NIMA;13;09/30/2006;;09/01/2007;
ARE0001/,47.544917,-122.635472,ADD,Fl Y 4s 4ft Priv
    Port Orchard Marina East Breakwater Lt,13|LN|2407|06/12/2007|06/15/2007|||
ARE0002/,47.374792,-122.459528,ADD,3_3 Obstn      Chart No. 1: K41
    Obstruction in Fathoms and Feet,13|CL|468-20|04/13/2007|05/29/2007|14153|
    2307||06/05/2007
ARE0003/,47.386156,-122.440778,ADD,1_1 Snag      Chart No. 1: K41
    2307||06/05/2007
ARE0004/,47.373425,-122.456428,ADD,1_2 Wk    Chart No. 1: K26
    Wreck in Fathoms and Feet,13|CL|468-20|04/13/2007|05/29/2007|14153||2307|
    06/05/2007
ARE0005/,47.268560,-122.555298,DEL,"D" Fl 4s Priv
    Tacoma Narrows Construction LMB D,13|CG|1307|03/27/2007|04/02/2007|||||
ARE0006/,47.274017,-122.555858,DEL,"A" Fl 4s Priv
    Tacoma Narrows Construction LMB A,13|CG|1307|03/27/2007|04/02/2007|||||
ARE0007/,47.272300,-122.550744,DEL,"B" Fl 4s Priv
    Tacoma Narrows Construction LMB B,13|CG|1307|03/27/2007|04/02/2007|||||
ARE0008/,47.271040,-122.559012,DEL,"C" Fl 4s Priv
    Tacoma Narrows Construction LMB C,13|CG|1307|03/27/2007|04/02/2007|||||
ARE0009/,47.562942,-122.534208,DEL,1 fm 5 ft,Sounding in Fathoms & Feet,13|CL
    137-20|03/30/2006|02/09/2007|13849||0807||02/20/2007
ARE0010/,47.562556,-122.533411,ADD
    rock with 3 fms 4 ft sounding; (Chart No. 1:K14.2) and label: Rk
    Rock in Fathoms and Feet,13|CL|137-20|03/30/2006|02/09/2007|13849||0807|
    02/20/2007
ARE0011/,47.661965,-122.435705,REV,Al WR 10s 27ft 16M HORN (Bl 10s)
    West Point Light,13|LN|0207|01/09/2007|01/11/2007|||||
ARE0012/,47.610778,-122.354389,DEL,5 fms 1 ft,Sounding in Fathoms & Feet,13|CL
    1370-2|11/17/2006|12/11/2006|13541||5106||12/19/2006
ARE0013/,47.610528,-122.354500,ADD,7 fms 3 ft,Sounding in Fathoms & Feet,13|CL
ARE0014/,47.587917,-122.377483,ADD,"A" W Or C   Priv,Seacrest Warning Buoy A,13
    LN|4506|11/07/2006|11/24/2006|||||
ARE0015/,47.588900,-122.378800,ADD,"B"  W Or C Priv,Seacrest Warning Buoy B,13
ARE0016/,47.590433,-122.380917,ADD,"C"  W Or C  Priv,Seacrest Warning Buoy C,13
ARE0017/,47.268333,-122.550000,DEL,HORNS (2),Tacoma Narrows Bridge HORNS,13|WN
    3906|09/30/2006|10/03/2006|||||
ARE0018/,47.273333,-122.556111,DEL,Fl 4s Priv
    Tacoma Narrows Outfall Pipe Lighted Buoy,13|LN|2806|07/11/2006|07/13/2006|
ARE0019/,47.341667,-122.341667,REV,3 Fl Y 4s Priv
    Redondo Floating Breakwater Lights (3),13|LN|2306|06/06/2006|06/12/2006|||
ARE0020/,47.272300,-122.550744,ADD,"B" Fl 4s Priv
    Tacoma Narrows Construction LMB B,13|LN|0406|01/24/2006|02/01/2006|||||
ARE0021/,47.271040,-122.559012,ADD,"C" Fl 4s Priv
    Tacoma Narrows Construction LMB C,13|LN|0406|01/24/2006|02/01/2006|||||
ARE0022/,47.268560,-122.555298,ADD,"D" Fl 4s Priv
    Tacoma Narrows Construction LMB D,13|LN|0406|01/24/2006|02/01/2006|||||
ARE0023/,47.274017,-122.555858,ADD,"A" Fl 4s Priv
    Tacoma Narrows Construction LMB A,13|LN|0406|01/24/2006|02/01/2006|||||
ARE0024/,47.576273,-122.420551,REV,Fl 5s 39 ft 15M,Alki Point Lt,13|LN|4505
    11/08/2005|11/15/2005|||||
ARE0025/,47.623385,-122.500533,ADD,W Or "A" Priv,Wyckoff Regulatory Buoy A,13
    LN|4505|11/08/2005|11/15/2005|||||
ARE0026/,47.623640,-122.504672,ADD,W Or "B" Priv,Wyckoff Regulatory Buoy B,13
ARE0027/,47.618358,-122.360369,ADD,Chart No. 1: L41.1,Sewer  PT 1 OF 2,13|CL
    36-200|08/22/2002|02/11/2005|10305||0805||02/22/2005
ARE0028/,47.617361,-122.361961,ADD,Chart No. 1: L41.1,Sewer  PT 2 OF 2,13|CL
ARE0029/,47.565552,-122.613699,REV,Fl R 6s 24ft 5M "12",Pt Herron LT 12,13|LN
    0305|01/18/2005|01/24/2005|||||
ARE0030/,47.453127,-122.438609,ADD,Fl 6s Priv,EAST VASHON OUTFALL LB,13|LN|4604
    11/16/2004|11/24/2004|||||
ARE0031/,47.282500,-122.410833,ADD
    SECURITY ZONE 165.1321 (see note A); Chart No. 1: N1.2
    Security Zone Point 1 of 6,13|CL|128004|08/27/2004|11/09/2004|8270||4604|
    11/16/2004
ARE0032/,47.284722,-122.414444,ADD,Chart No. 1: N1.2,Security Zone Point 2 of 6
    13|CL|128004|08/27/2004|11/09/2004|8270||4604||11/16/2004
ARE0033/,47.278333,-122.421667,ADD,Chart No. 1: N1.2,Security Zone Point 3 of 6
ARE0034/,47.273056,-122.426667,ADD,Chart No. 1: N1.2,Security Zone Point 4 of 6
ARE0035/,47.269444,-122.424167,ADD,Chart No. 1: N1.2,Security Zone Point 5 of 6
ARE0036/,47.269861,-122.422222,ADD,Chart No. 1: N1.2,Security Zone Point 6 of 6
ARE0037/,47.661667,-122.464722,REV,Y "SG" Fl Y 2.5s RACON (-.)
    PUGET SOUND LB SG,13|NC|18474|10/01/2003|10/05/2004|||||
ARE0038/,47.575833,-122.451389,REV,Y "T" Fl Y 2.5s,PUGET SOUND LB T,13|NC|18474
    10/01/2003|10/05/2004|8347||4104||10/12/2004
ARE0039/,47.271944,-122.419444,REV,F Y 14ft Priv,SITCUM WW LT,13|NC|18474
ARE0040/,47.285000,-122.410833,REV,F Y 7ft BELL Priv PA,PORT TACOMA #25 LT,13
    NC|18474|10/01/2003|10/05/2004|8347||4104||10/12/2004
ARE0041/,47.273333,-122.556111,ADD,Fl 4s Priv,TAKOMA NARROWS LB,13|LN|3704
    09/14/2004|09/20/2004|||||
ARE0042/,47.316778,-122.548111,REV,Fl 6s 21ft 9M HORN (Bl 15s)
    POINT DEFIANCE LT,13|LN|3504|08/31/2004|09/03/2004|||||
ARE0043/,47.278389,-122.416167,R&R,R "2" Fl R 4s Priv,BLAIR WATERWAY LB 2,13|LN
    2904|07/20/2004|07/26/2004|||||
ARE0044/,47.341667,-122.341667,ADD,3 Fl Y 4s Priv,REDONDO BKW LTS,13|LN|2204
    06/01/2004|06/08/2004|||||
ARE0045/,47.598861,-122.387917,REV,Fl 2.5s 15ft 15M,DUWAMISH HEAD LT,13|LN|1704
    04/27/2004|05/03/2004|||||
ARE0046/,47.447889,-122.404583,REV,Y "TA" Fl Y 2.5s,PUGET SOUND LB TA,13|LN
    5003|12/16/2003|12/19/2003|||||
ARE0047/,47.296111,-122.431222,DEL,PA,VISIBLE WRECK,13|BP|181343|08/28/2003
    11/06/2003|6928||4603||11/18/2003
ARE0048/,47.296361,-122.430167,ADD,7fm 4ft  Wk,SOUND IN FM & FT,13|BP|181343
    08/28/2003|11/06/2003|6928||4603||11/18/2003
ARE0049/,47.272333,-122.419972,DEL,Subm dols,SUBM DOLPHINS,13|BP|181343
ARE0050/,47.272833,-122.556833,ADD,Bridge under construction Pt 1 of 2
    BRIDGE DASH LINES,13|CL|113703|06/19/2003|10/25/2003|6726||4403|
    11/04/2003
ARE0051/,47.263444,-122.545194,ADD,Bridge under construction Pt 2 of 2
    BRIDGE DASH LINES,13|CL|113703|06/19/2003|10/25/2003|||||
ARE0052/,47.268583,-122.551500,ADD,NONE,MAGENTA SCREEN,13|CL|113703|06/19/2003
    10/25/2003|6726||4403||11/04/2003
ARE0053/,47.661417,-122.464528,REV,Y "SG" Fl Y 2.5s RACON (-.).,PUGET SD LB SG
    13|LN|4103|10/14/2003|10/23/2003|||||
ARE0054/,47.513694,-122.473167,REL,Fl 4s 17ft 7M,POINT VASHON LIGHT,13|LN|4103
ARE0055/,47.575944,-122.451250,REV,Y "T" Fl Y 2.5s,PUGET SOUND SEP LB T,13|LN
OST/1
IFM/4
RGB/1,0,0,0
RGB/2,255,255,255
RGB/3,244,232,193
RGB/4,239,216,163
RGB/5,214,219,201
RGB/6,219,181,242
RGB/7,170,216,229
RGB/8,145,145,145
RGB/9,114,114,114
RGB/10,150,176,155
RGB/11,94,153,193
RGB/12,219,73,150
RGB/13,209,221,239
DAY/1,0,0,0
DAY/2,255,255,255
DAY/3,238,223,161
DAY/4,214,192,107
DAY/5,181,181,123
DAY/6,219,181,242
DAY/7,170,216,229
DAY/8,145,145,145
DAY/9,114,114,114
DAY/10,38,212,84
DAY/11,37,138,191
DAY/12,219,73,150
DAY/13,185,210,240
DSK/1,0,0,0
DSK/2,128,128,128
DSK/3,119,112,81
DSK/4,107,96,54
DSK/5,91,91,62
DSK/6,110,91,121
DSK/7,85,108,115
DSK/8,73,73,73
DSK/9,57,57,57
DSK/10,19,106,42
DSK/11,19,69,96
DSK/12,110,37,75
DSK/13,93,105,120
NGT/1,55,55,55
NGT/2,0,0,0
NGT/3,30,21,13
NGT/4,24,19,10
NGT/5,0,23,12
NGT/6,17,0,0
NGT/7,0,15,15
NGT/8,30,30,30
NGT/9,35,35,35
NGT/10,1,50,1
NGT/11,0,55,55
NGT/12,64,0,64
NGT/13,0,0,38
NGR/1,0,0,0
NGR/2,255,0,0
NGR/3,220,0,0
NGR/4,191,0,0
NGR/5,175,0,0
NGR/6,213,0,0
NGR/7,199,0,0
NGR/8,145,0,0
NGR/9,114,0,0
NGR/10,120,0,0
NGR/11,104,0,0
NGR/12,145,0,0
NGR/13,204,0,0
GRY/1,0,0,0
GRY/2,255,255,255
GRY/3,215,215,215
GRY/4,191,191,191
GRY/5,175,175,175
GRY/6,203,203,203
GRY/7,199,199,199
GRY/8,145,145,145
GRY/9,114,114,114
GRY/10,120,120,120
GRY/11,104,104,104
GRY/12,138,138,138
GRY/13,199,199,199
PRC/1,0,0,0
PRC/2,255,255,255
PRC/3,247,239,181
PRC/4,214,192,107
PRC/5,181,191,123
PRC/6,219,181,242
PRC/7,170,216,229
PRC/8,140,140,140
PRC/9,114,114,114
PRC/10,38,212,84
PRC/11,37,138,191
PRC/12,219,73,150
PRC/13,181,206,240
PRG/1,0,0,0
PRG/2,255,255,255
PRG/3,222,222,222
PRG/4,191,191,191
PRG/5,175,175,175
PRG/6,213,213,213
PRG/7,199,199,199
PRG/8,145,145,145
PRG/9,114,114,114
PRG/10,120,120,120
PRG/11,104,104,104
PRG/12,145,145,145
PRG/13,204,204,204
REF/1,514,11759,47.2631666667,-122.7112500000
REF/2,514,595,47.6648333333,-122.7112500000
REF/3,7991,595,47.6648333333,-122.3145722222
REF/4,7991,11759,47.2631666667,-122.3145722222
REF/5,7637,11759,47.2631666667,-122.3333305556
REF/6,7637,9815,47.3333361111,-122.3333305556
REF/7,7637,7503,47.4166694444,-122.3333305556
REF/8,7637,5187,47.5000055556,-122.3333305556
REF/9,7637,2867,47.5833388889,-122.3333305556
REF/10,7637,595,47.6648333333,-122.3333305556
REF/11,6067,11759,47.2631666667,-122.4166666667
REF/12,6067,9815,47.3333361111,-122.4166666667
REF/13,6067,7503,47.4166694444,-122.4166666667
REF/14,6067,5187,47.5000055556,-122.4166666667
REF/15,6067,2867,47.5833388889,-122.4166666667
REF/16,6067,595,47.6648333333,-122.4166666667
REF/17,4496,11759,47.2631666667,-122.4999888889
REF/18,4496,9815,47.3333361111,-122.4999888889
REF/19,4496,7503,47.4166694444,-122.4999888889
REF/20,4496,5187,47.5000055556,-122.4999888889
REF/21,4496,2867,47.5833388889,-122.4999888889
REF/22,4496,595,47.6648333333,-122.4999888889
REF/23,2925,11759,47.2631666667,-122.5833222222
REF/24,2925,9815,47.3333361111,-122.5833222222
REF/25,2925,7503,47.4166694444,-122.5833222222
REF/26,2925,5187,47.5000055556,-122.5833222222
REF/27,2925,2867,47.5833388889,-122.5833222222
REF/28,2925,595,47.6648333333,-122.5833222222
REF/29,1355,11759,47.2631666667,-122.6666583333
REF/30,1355,9815,47.3333361111,-122.6666583333
REF/31,1355,7503,47.4166694444,-122.6666583333
REF/32,1355,5187,47.5000055556,-122.6666583333
REF/33,1355,2867,47.5833388889,-122.6666583333
REF/34,1355,595,47.6648333333,-122.6666583333
REF/35,7991,9815,47.3333361111,-122.3145722222
REF/36,514,9815,47.3333361111,-122.7112500000
REF/37,7991,7503,47.4166694444,-122.3145722222
REF/38,514,7503,47.4166694444,-122.7112500000
REF/39,7991,5187,47.5000055556,-122.3145722222
REF/40,514,5187,47.5000055556,-122.7112500000
REF/41,7991,2867,47.5833388889,-122.3145722222
REF/42,514,2867,47.5833388889,-122.7112500000
PLY/1,47.2631666667,-122.7112500000
PLY/2,47.6648333333,-122.7112500000
PLY/3,47.6648333333,-122.3145833333
PLY/4,47.2631666667,-122.3145833333
DTM/0.0000000000,0.0000000000
CPH/0.0000000000
WPX/2,2311576.545,18815.75937,-6.309108497,-0.140182405,-0.03549536405
    0.02065585633
WPY/2,708186.4854,11.00559239,-1757.49152,0.04301906108,-0.009801777112
    -274.2927295
PWX/2,-122.738527,5.305438564e-005,5.898059818e-016,5.22985145e-014
    -2.096406544e-020,-3.695181232e-020
PWY/2,47.68614829,-5.551115123e-017,-3.582066646e-005,3.494010907e-021
    3.494010907e-021,-1.277429242e-011
ERR/1,0.1356320000,0.0067008300,0.0000000566,0.0000070259
ERR/2,0.1386000000,0.0701996000,0.0000028586,0.0000070259
ERR/3,0.1137070000,0.0711470000,0.0000028586,0.0000061636
ERR/4,0.1110200000,0.0060865600,0.0000000566,0.0000061636
ERR/5,0.3248400000,0.0064205700,0.0000000566,0.0000170449
ERR/6,0.3239370000,0.0596109000,0.0000017397,0.0000170449
ERR/7,0.3231280000,0.0678959000,0.0000027401,0.0000170449
ERR/8,0.3226070000,0.0822854000,0.0000027508,0.0000170449
ERR/9,0.3223720000,0.1708380000,0.0000065533,0.0000170449
ERR/10,0.3224200000,0.0714072000,0.0000028586,0.0000170449
ERR/11,0.4267990000,0.0075384700,0.0000000566,0.0000225555
ERR/12,0.4274950000,0.0585503000,0.0000017397,0.0000225555
ERR/13,0.4280560000,0.0688884000,0.0000027401,0.0000225555
ERR/14,0.4283310000,0.0832098000,0.0000027508,0.0000225555
ERR/15,0.4283190000,0.1699820000,0.0000065533,0.0000225555
ERR/16,0.4280300000,0.0721970000,0.0000028586,0.0000225555
ERR/17,0.0813985000,0.0080588000,0.0000000566,0.0000045300
ERR/18,0.0809105000,0.0580873000,0.0000017397,0.0000045300
ERR/19,0.0805951000,0.0692834000,0.0000027401,0.0000045300
ERR/20,0.0805667000,0.0835367000,0.0000027508,0.0000045300
ERR/21,0.0808251000,0.1697230000,0.0000065533,0.0000045300
ERR/22,0.0813553000,0.0723893000,0.0000028586,0.0000045300
ERR/23,0.3782220000,0.0079817500,0.0000000566,0.0000202462
ERR/24,0.3779420000,0.0582217000,0.0000017397,0.0000202462
ERR/25,0.3778730000,0.0690810000,0.0000027401,0.0000202462
ERR/26,0.3780910000,0.0832662000,0.0000027508,0.0000202462
ERR/27,0.3785960000,0.1700620000,0.0000065533,0.0000202462
ERR/28,0.3793670000,0.0719841000,0.0000028586,0.0000202462
ERR/29,0.3792570000,0.0073071900,0.0000000566,0.0000201280
ERR/30,0.3793300000,0.0589535000,0.0000017397,0.0000201280
ERR/31,0.3791530000,0.0682810000,0.0000027401,0.0000201280
ERR/32,0.3786880000,0.0823982000,0.0000027508,0.0000201280
ERR/33,0.3779370000,0.1709980000,0.0000065533,0.0000201280
ERR/34,0.3769240000,0.0709815000,0.0000028586,0.0000201280
ERR/35,0.1119700000,0.0599320000,0.0000017397,0.0000061636
ERR/36,0.1356700000,0.0595906000,0.0000017397,0.0000070259
ERR/37,0.1128340000,0.0675901000,0.0000027401,0.0000061636
ERR/38,0.1359790000,0.0676076000,0.0000027401,0.0000070259
ERR/39,0.1134110000,0.0819949000,0.0000027508,0.0000061636
ERR/40,0.1365760000,0.0816883000,0.0000027508,0.0000070259
ERR/41,0.1137010000,0.1711130000,0.0000065533,0.0000061636
ERR/42,0.1374590000,0.1717440000,0.0000065533,0.0000070259
