[gdal-dev] gdalwarp - Invalid Tiled GTiff
Aaron Sutula
Aaron.Sutula at noaa.gov
Fri Oct 10 12:55:57 EDT 2008
Hi Frank,
I built the svn development version of gdal with all internal libraries
and that did the trick; 1.5.2 still had the bug. Thanks for the help.
Aaron
Frank Warmerdam wrote:
> Aaron Sutula wrote:
>> Hi List,
>> I am attempting to create a mosaic of elevation data I have stored as
>> a bunch of geotiff files. I am trying this with gdalwarp from FWtools
>> 2.0.6 (so there is bigtiff support). My approach is to gdalwarp one
>> of the source geotiffs into an output geotiff and specify that the
>> output geotiff has a larger extent, my final extent for the mosaic.
>> After that, I can gdalwarp the remaining source geotiffs into the
>> first output geotiff.
>> $ du merge18.tif
>> 2111768 merge18.tif
>> $ gdalinfo merge18.tif
>> ERROR 4: `merge18.tif' not recognised as a supported file format.
>> gdalinfo failed - unable to open 'merge18.tif'.
> Aaron,
> I think you are hitting the 2GB barrier. A while ago we discovered the
> logic for switching to the "large file api" which is necessary past 2GB
> was not working properly in some unix and linux builds due to an
> unexpected
> error code being returned from fopen(). This is exactly how it
> manifests.
> Unfortunately there isn't a newer FWTools with the fix though the problem
> is fixed. If you can build from source yourself you should be ok. Or
> if you can keep the size a bit below 2GB you should be ok.
> Best regards,
