[Gdal-dev] OGR: DXF driver
Fodder
cryan at csse.com.au
Tue Oct 14 21:42:48 EDT 2008
Hi Frank,
Thanks, this would be great, although I can't fund it in completion (Euro
>>>> Aussie dollar :) .Would you be prepared to develop just the READ side
of the driver, and what do you think that would cost (without styling)?
Alternatively, are other users/organisations interested in jointly
contributing?
On your proposal, you say that it would not support REGION, is it normal for
polygons to be recorded as special polylines in DXF (such as from AutoCAD
for example)?
Would it support attributes, such as a DXF of contour lines with elevation
attributes?
Cheers,
Fodder
Frank Warmerdam-2 wrote:
> Fodder wrote:
>> Hi All,
>> I am also very keen for an OGR DXF/DWG driver that supports reading and
>> writing. I imagine there would be many people that would take advantage
>> of
>> this capability.
>> I would also be willing to contribute financially if somebody wanted to
>> take
>> the project on board. I may not be able to fund the entire development,
>> but
>> perhaps there are others that might also contribute....
> Folks,
> I had a client request for a simple DXF read/write driver and prepared
> the following proposal. It might prove to be of interest to someone
> interested in implementing DXF support. Alternatively if someone wanted
> to fund the work I would be prepared to do it under these terms. I'd
> prefer not to do the styling work if I could avoid it - or at least
> leave it as a follow on effort.
> OGR DXF Read/Write Driver
> Purpose
> To implement a read/write OGR DXF driver.
> Technical Notes
> Generally speaking the implementation will be done on the basis of the
> DXF 2000 specification from Autodesk. Features of newer versions of DXF
> will not generally be supported, though hopefully some newer DXF files
> can be read if they use older styles of geometric objects. The provided
> sample files were for an older version of AutoCAD than DXF 2000 and should
> be well supported.
> * At a minimum the following DXF geometry types should be supported for
> reading:
> LINE, POLYLINE, LWPOLYLINE, POINT, VERTEX, TEXT
> * The following geometric types will be supported for reading if
> suitable
> examples are available, and if the client indicates an interest:
> ARC, CIRCLE, 3DFACE, ELLIPSE, MLINE, SPLINE
> * There are no plans to implement the following geometric types:
> IMAGE, REGION, HATCH, OLE*, SHAPE, RAY, MTEXT, BODY, 3DSOLID,
> ATTRIB,
> DIMENSION, INSERT, LEADER, VIEWPORT, WIPEOUT
> * When reading and writing the Polyline flag "1" code will be used to
> mark and recognise POLYLINE objects that are actually rings of a
> polygon
> (as is generated by the shpdxf utility for instance).
> * In general the DXF writer will write point geometries as POINT,
> linestrings as POLYLINE and polygons as specially marked POLYLINEs.
> Features with collection geometries (MULTIPOLYGON, MULTILINE,
> MULTIPOINT,
> GEOMETRYCOLLECTION) will be written as if each component geometry was
> a
> feature.
> * For the most part section of the DXF file other than the ENTITIES
> section
> will be ignored, or written in a minimal form.
> * Each feature read will have a "LAYER" attribute. All features in one
> DXF
> file will be treated as a single OGRLayer (named according to the
> basename
> of the dxf file).
> * When writing, the DXF LAYER name will be written from the
> corresponding
> feature attribute named LAYER - if that does not exist it will be
> written from the name associated with the OGRLayer.
> * There is no standard coordinate system definition approach for DXF,
> so the OGR DXF driver would not support reading or writing coordinate
> system definitions.
> OGR Feature Styling
> As an optional item, an attempt will be made to capture feature styling
> (line color, line width, text size and angle, etc) in the form defined by
> the OGR Feature Style Specification:
> http://www.gdal.org/ogr/ogr_feature_style.html
> This associates the feature styling with a feature in a special text
> format. These feature style strings are utilized by a few OGR client
> applications to display features as originally intended. Currently the
> main applications honouring OGR feature style strings are MapServer and
> OpenEV. The other file formats supported in this manner are DGN and
> Mapinfo.
> Feature styling would also be utilized to produced styled DXF entities
> if available in the source features when writing to DXF.
> Prototyping
> The OGR DXF read/write driver being proposed here should be considered
> to be a prototype or "limited use" DXF driver. It will be tailored for
> the
> requirements of the particular client, and will have many limitations. If
> a very general purpose DXF driver is desired, a second implementation
> phase
> might be contemplated, and would operate based on the lessons learned
> during
> implementation and use of this original driver.
> Sample Data
> During implementation a variety of sample data will be collected from the
> internet. It is also important that the client supply a variety of sample
> datasets representative of the sorts of DXF files they desire to be able
> to read.
> Intellectual Property
> The resulting OGR DXF driver will be placed under the usual GDAL/OGR MIT/X
> style open source license. The copyright may be held by the client, or if
> they do not wish this, by Frank Warmerdam.
> The intention is to implement this component from scratch, and there
> are no expected dependencies on external libraries like DIME, dxflib or
> the Open Design Alliance libraries.
> Pricing
> Basic Read/Write OGR DXF Driver: 2200 Euros
> OGR Feature Styling: 1200 Euros
> Timeline
> A preliminary driver would be delivered (in source form) within four weeks
> of
> proposal acceptance. A final driver (incorporating client feedback) would
> be completed within two weeks of receiving client feedback.
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://www.nabble.com/OGR%3A-DXF-driver-tp19899742p19985330.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
