[Gdal-dev] OGR: DXF driver
Frank Warmerdam
warmerdam at pobox.com
Wed Oct 15 11:10:41 EDT 2008
Fodder wrote:
> Hi Frank,
> Thanks, this would be great, although I can't fund it in completion (Euro
>>>>> Aussie dollar :) .Would you be prepared to develop just the READ side
> of the driver, and what do you think that would cost (without styling)?
Fodder,
I would be willing to implement only read support, though it would not
reduce the pricing all that much.
> Alternatively, are other users/organisations interested in jointly
> contributing?
> On your proposal, you say that it would not support REGION, is it normal for
> polygons to be recorded as special polylines in DXF (such as from AutoCAD
> for example)?
I'm afraid I'm not entirely sure what is normal. I reviewed DXF docs,
a couple example files, and the GRASS DXF import program in preparing the
proposal, but DXF is still a bit of a mystery to me. The proposal was
deliberately simplistic to match my current level of understanding.
> Would it support attributes, such as a DXF of contour lines with elevation
> attributes?
Generally no, though there is some opportunity improve the driver a bit
for easily recognizable attributes. I have avoided doing a DXF driver for
many years because while the format is not so complicated, there are a
wide variety of ways for applications to encode complete geometries and
attach attributes.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
