[gdal-dev] get fmrt grib
Wed Oct 15 11:02:14 EDT 2008
Limei Ran wrote:
> Hi Frank:
> I got gdal-svn-trunk-2008.10.14.tar.gz.  When I compiled it on Linux
> server 32bits I got the following errors:
> gt_overview.cpp: In function `toff_t GTIFFWriteDirectory(TIFF*, int,
> int, int, int, int, int, int, int, int, int, int, int, short unsigned
> int*, short unsigned int*, short unsigned int*, int, short unsigned
> int*, const char*)':
> gt_overview.cpp:75: error: `TIFFFreeDirectory' was not declared in this
> scope
> gt_overview.cpp:75: warning: unused variable 'TIFFFreeDirectory'
> make[2]: *** [../o/gt_overview.o] Error 1
> make[2]: Leaving directory
> `/nas/uncch/depts/cep/emc/lran/mims/mimssp_10_2007/src/libs/gdal-svn-trunk-2008.10.14/frmts/gtiff'
> make[1]: *** [gtiff-install-obj] Error 2
> make[1]: Leaving directory
> `/nas/uncch/depts/cep/emc/lran/mims/mimssp_10_2007/src/libs/gdal-svn-trunk-2008.10.14/frmts'
> make: *** [frmts-target] Error 2
Limei,
I have checked, and TIFFFreeDirectory() has existed in libtiff since 2003 so
I find it hard to imagine you have a libtiff so old it lacks this function.
But, try configuring with the option "--with-libtiff=internal" and see if that
helps.
Best regards,
