[gdal-dev] get fmrt grib
Limei Ran lran at unc.edu
Thu Oct 16 14:42:40 EDT 2008
Hi Frank:
Thank you very much and it worked.
Limei
Frank Warmerdam wrote:
> Limei Ran wrote:
>> Hi Frank:
>> I got gdal-svn-trunk-2008.10.14.tar.gz.  When I compiled it on Linux
>> server 32bits I got the following errors:
>> gt_overview.cpp: In function `toff_t GTIFFWriteDirectory(TIFF*, int,
>> int, int, int, int, int, int, int, int, int, int, int, short unsigned
>> int*, short unsigned int*, short unsigned int*, int, short unsigned
>> int*, const char*)':
>> gt_overview.cpp:75: error: `TIFFFreeDirectory' was not declared in
>> this scope
>> gt_overview.cpp:75: warning: unused variable 'TIFFFreeDirectory'
>> make[2]: *** [../o/gt_overview.o] Error 1
>> make[2]: Leaving directory
>> `/nas/uncch/depts/cep/emc/lran/mims/mimssp_10_2007/src/libs/gdal-svn-trunk-2008.10.14/frmts/gtiff'
>> make[1]: *** [gtiff-install-obj] Error 2
>> make[1]: Leaving directory
>> `/nas/uncch/depts/cep/emc/lran/mims/mimssp_10_2007/src/libs/gdal-svn-trunk-2008.10.14/frmts'
>> make: *** [frmts-target] Error 2
> Limei,
> I have checked, and TIFFFreeDirectory() has existed in libtiff since
> 2003 so
> I find it hard to imagine you have a libtiff so old it lacks this
> function.
> But, try configuring with the option "--with-libtiff=internal" and see
> if that
> helps.
> Best regards,
