[gdal-dev] error using gdaltindex on grass rasters
Jamie Adams
jaadfoo at gmail.com
Wed Oct 15 13:29:49 EDT 2008
Hello all,
I needed to create a shapefile index of all the rasters in a grass mapset so
I ran:
ls /grass/location/mapset/cellhd/* | xargs gdaltindex all.shp
and got this error:
Warning 1: GRASS warning: Unable to open datum table file
</usr/local/share/gdal/grass//etc/datum.table>
/usr/local/share/gdal/grass//etc/ellipse.table: No such file or directory
Warning 1: GRASS warning: Unable to open ellipsoid table file
</usr/local/share/gdal/grass//etc/ellipse.table>
Warning 1: GRASS fatal error: Invalid ellipsoid <wgs84> in file
I created a symlink 'grass' in /usr/local/share/gdal/ pointing to my grass
install root, and that seemed to fix the issue.
I built both gdal and grass from source, plus added gdal-grass read support
via http://trac.osgeo.org/gdal/wiki/GRASS. Should gdaltindex work as-is, or
did I miss a step somewhere?
Thanks,
-Jamie
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081015/88d578e4/attachment.html
