[gdal-dev] error using gdaltindex on grass rasters
Markus Neteler neteler at osgeo.org
Wed Oct 15 16:45:52 EDT 2008
On Wed, Oct 15, 2008 at 7:29 PM, Jamie Adams <jaadfoo at gmail.com> wrote:
> Hello all,
> I needed to create a shapefile index of all the rasters in a grass mapset so
> I ran:
> ls /grass/location/mapset/cellhd/* | xargs gdaltindex all.shp
> and got this error:
> Warning 1: GRASS warning: Unable to open datum table file
> </usr/local/share/gdal/grass//etc/datum.table>
> /usr/local/share/gdal/grass//etc/ellipse.table: No such file or directory
> Warning 1: GRASS warning: Unable to open ellipsoid table file
> </usr/local/share/gdal/grass//etc/ellipse.table>
> Warning 1: GRASS fatal error: Invalid ellipsoid <wgs84> in file
Since GDAL 1.3.1 it should be resolved, see
http://trac.osgeo.org/gdal/ticket/822
Which version do you use?
Markus
> I created a symlink 'grass' in /usr/local/share/gdal/ pointing to my grass
> install root, and that seemed to fix the issue.
> I built both gdal and grass from source, plus added gdal-grass read support
> via http://trac.osgeo.org/gdal/wiki/GRASS.  Should gdaltindex work as-is, or
> did I miss a step somewhere?
> Thanks,
> -Jamie
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
