[Gdal-dev] Is Gdal2tiles working somewhere?
darrepac
pascal.darre at laposte.net
Tue Oct 21 03:56:53 EDT 2008
Hello Klokan
Klokan Petr Přidal wrote:
> In case you would like to only add WMS map to the generated OpenLayers
> viewer with TMS tiles please check the OpenLayers project
> documentation and the example
> http://www.openlayers.org/dev/examples/spherical-mercator.html, which
> includes both TMS and WMS layer.
> The example HTML viewer generated by old GDAL2Tiles is using pixel
> based coordinates, but there is commented section with sample of
> projected coordinate specification in the code as well. Just play a bit
> with the
> JavaScript code...
> I will repair that in the new version of GDAL2Tiles...
You get it! I would like to see the same example of Grand Canyon but with
openlayers. I tried to play with the commented section of the generated
openlayers html but without success so far.
View this message in context: http://www.nabble.com/Is-Gdal2tiles-working-somewhere--tp20056950p20085245.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
