[gdal-dev] Java build error in GDAL 1.5.3
Daniele Romagnoli
dany.geotools at gmail.com
Mon Oct 27 11:22:28 EDT 2008
the thing I have noticed in 1.5.3 is that in "swig/include/gdal.i" there is:
#if !defined(SWIGJAVA)
%include "ColorTable.i"
#endif
In case you are building JAVA bindings, the include will be skipped
resulting in errors.
Not sure why this has been added.
In the patch I have provided to Mike, I have removed the !defined/endif
directives.
Moreover, in the patch, for "swig/include/java/gdal_java.i", the line:
"%typemap(javaimports) GDALColorTable %{"
have been substitued by
"%typemap(javaimports) GDALColorTableShadow %{"
Daniele
On Mon, Oct 27, 2008 at 3:26 PM, Nidel, Mike <mike.nidel at lmco.com> wrote:
> I've just updated to the tagged 1.5.3 version of GDAL. I'm building the
> Swig Java bindings, and I'm getting the following build error
> (truncated, occurs a total of 8 times):
> Buildfile: build.xml
> compile:
> [javac] Compiling 39 source files to
> C:\src\gdal-1.5.3\swig\java\build\class
> es
> [javac]
> C:\src\gdal-1.5.3\swig\java\org\gdal\gdal\ColorTable.java:35: cannot
> find symbol
> [javac] symbol : method delete_ColorTable(long)
> [javac] location: class org.gdal.gdal.gdalJNI
> [javac] gdalJNI.delete_ColorTable(swigCPtr);
> [javac] ^
> I know this relates to a patch that was provided by Daniele over at
> Geosolutions. I applied the patch to a previous build but haven't
> applied it to the 1.5.3 baseline on my system.
> Is there any intention of fixing this in GDAL? Is it possible I've
> missed or forgotten some discussion on the topic? Perhaps it's fixed in
> a more recent build?
> Mike
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081027/3c1c41d4/attachment.html
