[gdal-dev] RE: progressive rendering
Norman Barker
nbarker at ittvis.com
Tue Sep 2 19:42:49 EDT 2008
I have updated the RFC
http://trac.osgeo.org/gdal/wiki/rfc24_progressive_data_support
To take in all of your comments, and I have added a comment about how
this is a progressive format driver, but is no longer asynchronous, and
I am not sure how it ever could be asynchronous within the driver since
the methods block. It moves the thread handling to the user, which is a
fair trade-off over simplicity and abstracting some of the nastier
features of the protocol implemented.
I am not really a c++ developer (please do point out any stupid errors I
may have made), but have written JPIP server and clients (in Java) and
think the design (which in the main has come from Adam, Tamas, Even -
not me) is a good (and a simple) one. It would be relatively easy to
implement, I added the papzOptions to the method call as a general catch
all for format implementations.
Please direct your comments and improvements to specific items within
the RFC so that it can be shaped to something that can potentially be
approved and hence implemented.
Many thanks,
Norman
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Adam Nowacki
Sent: Tuesday, September 02, 2008 1:40 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] RE: progressive rendering
Tamas Szekeres wrote:
> Hi All,
> Upon thinking about the issues I've been come up with previously, I
> consider the following approach could be implemented easily either at
> driver or at SWIG interface level. Requires a new class to be
> implemented by the async IO supported drivers and a new additional
> method should be added to the GDALDataset and GDALRasterBand.
> The user could implement the async IO by using the following pseudo
sequence:
> <Code>
> </Code>
I like it :)
typedef enum {
CE_Again = 5 // timeout, buffer not updated, call RasterIO() again
} CPLErr;
typedef enum { // Async raster io status
GRS_Complete = 0, // raster io is complete, call to
GDALRasterIOContext->RasterIO() will return CE_Failure
GRS_InProgress = 1, // raster io in progress, call
GDALRasterIOContext->RasterIO() to get more data
GRS_Error = 2 // error, call to GDALRasterIOContext->RasterIO()
} GDALRasterIOStatus;
typedef enum { // Hints for GDALRasterIOContext->RasterIO(), driver
implementations may ignore any or all
GRH_SingleBlock = 0x1, // exit after single block update, even if
there is more data immediately available
GRH_Progressive = 0x2, // update with lower resolution data / fill
with interlaced rows
GRH_WaitForTimeout = 0x4 // wait for timeout even if already
updated some data
} GDALRasterIOHint;
class GDALRasterIOContext {
public:
GDALRasterIOContext() {
eStatus = GRS_Continue;
pszError = NULL;
public:
// Continue raster io, update pData buffer with new data, nUpdate??? =
bounding box of all updated blocks
// return CE_None if updated with new data
// return CE_Again on timeout
// return CE_Failure on error
virtual CPLErr RasterIO(void *pData, int nTimeoutMilliseconds = -1,
int nHint = 0);
public:
GDALRasterIOStatus eStatus;
char *pszError; // if eStatus == GRS_Error this should contain
human readable error message, NULL otherwise
int nUpdateXOff;
int nUpdateYOff;
int nUpdateXSize;
int nUpdateYSize;
class GDALDataset {
public:
virtual GDALRasterIOContext *StartRasterIO(
GDALRWFlag eRWFlag, int nXOff, int nYOff, int nXSize, int
nYSize,
int nBufXSize, int nBufYSize, GDALDataType eBufType,
int nBandCount, int *panBandMap, int nPixelSpace, int
nLineSpace, int nBandSpace
virtual void EndRasterIO(GDALAsyncRasterIOContext *poContext);
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
