[gdal-dev] inflateCopy required?
Fri Sep 5 17:29:37 EDT 2008
Brent Fraser wrote:
> I just did a checkout and build of GDAL, and got the following:
>   Creating library gdal_i.lib and object gdal_i.exp
> cpl_vsil_gzip.obj : error LNK2019: unresolved external symbol
> _inflateCopy referenced in function "public: class VSIGZipHandle *
> __thiscall VSIGZipHandle::Duplicate(void)"
> (?Duplicate at VSIGZipHandle@@QAEPAV1 at XZ)
> gdal16dev.dll : fatal error LNK1120: 1 unresolved externals
> Where can I find the "inflateCopy " function? Zlib?  Should nmake.opt be
> updated to include a definition to Zlib?
Brent,
Normally I think the internal copy of zlib (gdal/frmts/zlib) should
provide that function.  Is it possible you are building in an unconventional
fashion or are using an external zlib of a different version?
Best regards,
