[gdal-dev] cannot seem to get projection data from an aux.xml file correctly.
Robert Beckwith Robert.Beckwith at delorme.com
Wed Sep 10 10:14:14 EDT 2008
I am using GDALPamDataset::GetProjectionRef() to fetch the definition
string for the dataset.
Then use that to importFromWkt with that definition and then CloneGeoCS
to set up a coordinate transformation I need to use.
This works fine for MrSID files that have a .aux file.
But,  When I use the same methods with a MrSID file with an aux.xml file
this does not work.
I am thinking that when I call GetProjectionRef() the string is labeled
LOCAL_CS this in turn ends up failing later down the line.
Especially when trying to CloneGeoCS as no  GEOGCS node exists.
I am looking for some help to get this working for aux.xml files.
Thanks.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080910/90674252/attachment.html
