[gdal-dev] gdal 1.5.2's RADARSAT-2 driver
Gong, Shawn (Contractor)
Shawn.Gong at drdc-rddc.gc.ca
Fri Sep 12 16:26:51 EDT 2008
Frank,
The error (TIFFReadDirectory:Unknown field with tag 34595 (0x8723)
encountered) only shown on the very first batch of test R-2 images.
The official release R-2 data do not show the error.
thanks,
Shawn
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: Friday, September 12, 2008 3:41 PM
To: Gong, Shawn (Contractor)
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] gdal 1.5.2's RADARSAT-2 driver
Gong, Shawn (Contractor) wrote:
> hi list,
> rephrase my 2nd question, is there a way to skip the "SubDataset
> Selection" dialog, and to load uncalibrated digital numbers by
default?
Shawn,
I think this may be more of an OpenEV question, than it is a GDAL
question. You can directly select the uncalibrated numbers by
using the appropriate subdatset name with GDAL. You can use gdalinfo
to see the subdataset names of a dataset.
> *From:* gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Gong, Shawn
> (Contractor)
> *Sent:* Friday, September 12, 2008 2:28 PM
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* [gdal-dev] gdal 1.5.2's RADARSAT-2 driver
> hi list,
> I have installed gdal 1.5.2 on Windows, trying to test the RADARSAT-2
> driver.
> When loading RSAT-2 "product.xml", a "SubDataset Selection" dialog box
> pops up and asks user to select 1) uncalibrated digital numbers, 2)
> Sigma nought calibrated, 3) beta nought calibrated, 4) gamma
calibrated.
> After selection, I got the error:
> Warning 1: TIFFReadDirectory:Unknown field with tag 34595 (0x8723)
> encountered
> and the "SubDataset Selection" dialog box reappears.
Hmm, this is odd. Would it be possible to make a dataset demonstrating
this problem available?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
