[gdal-dev] gdaltransform results differs from qgis
Antonio Parrotta antonioparrotta at gmail.com
Mon Sep 15 06:03:22 EDT 2008
I'm trying proj4 too, but after downloaded binary and
set PROJ_LIB=<nad_intallation_dir>
set set PATH=%PATH%;<bin_intallation_path>
>cs2cs -v  +proj=latlong +datum=WGS84 +to +init=epsg:3003
+towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
I obtain :
Using to definition: init=epsg:3003
Rel. 4.4.6, 3 March 2003
<cs2cs>:
projection initialization failure
cause: no options found in 'init' file
program abnormally terminated
maybe I'm missing some file,  is it?
thanks
Antonio
2008/9/15 Antonio Parrotta <antonioparrotta at gmail.com>
> I downloaded the source from http://download.osgeo.org/gdal/gdal152.zip,
> built on windows XP with VC2008 with and PROJ4 dll from
> http://download.osgeo.org/proj/proj446_win32_bin.zip
> any clue
> Antonio
> 2008/9/15 Markus Neteler <neteler at osgeo.org>
> On Mon, Sep 15, 2008 at 11:02 AM, Antonio Parrotta
>> <antonioparrotta at gmail.com> wrote:
>> > Hi All,
>> > I'm facing in  strange result using gdaltransform. What I'm doing is to
>> try
>> > to trasform coordinates from WGS84 to Gauss-Boaga:
>> > gdaltransform.exe -s_srs "WGS84" -t_srs "+proj=tmerc +ellps=intl
>> +lat_0=0
>> > +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0 +units=m
>> > +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68"
>> > entering lon and lat
>> >>7,69746 45,106977<enter>
>> > it gives
>> > 1342393.88434212 4984915.97865081 -47.0342488819733
>> > doing the same transformation with qgis (same parameters), I have
>> > 1397559,446 4995677,02
>> > that is quite near to the target expected also checking out in map.
>> > Do we know the reason of this delta? Do I have to set any other
>> correction
>> > parameter?
>> Using cs2cs from PROJ4 Rel. 4.6.1, 21 July 2008, I get:
>> # ---- From Coordinate System ----
>> #Lat/long (Geodetic alias)
>> # +proj=latlong +datum=WGS84 +ellps=WGS84 +towgs84=0,0,0
>> # ---- To Coordinate System ----
>> #Transverse Mercator
>> #       Cyl, Sph&Ell
>> # +init=epsg:3003 +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
>> # +no_defs +proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0
>> # +ellps=intl +units=m
>> #--- following specified but NOT used
>> # +no_defs
>> 7.69746 45.106977
>> 1397556.77      4995679.28 -46.70
>> Using gdaltransform on Linux (almost current SVN), I get:
>> gdaltransform -s_srs "WGS84" -t_srs "+proj=tmerc +ellps=intl +lat_0=0 \
>>   +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0 +units=m \
>> 7.69746 45.106977
>> 1397556.76994996 4995679.27916302 -46.6971342787147
>> which is the same as the cs2cs output.
>> How old is your gdaltransform.exe and where does it originate from?
>> Markus
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080915/1116e08e/attachment-0001.html
