[gdal-dev] About Gdal contour - Opinion
Frank Warmerdam
warmerdam at pobox.com
Tue Sep 16 12:11:02 EDT 2008
2008/9/16 Antonio Pérez <aperezcarro at yahoo.es>:
> Hello everybody
> I would want to know your opinion about gdal-contour
> I dont see messages about it into the list ....
> Do you use it ? What grade of results can be got ?
Antonio,
I know a few people use it though it isn't heavily used.
I'm pretty confident it does what it is supposed to do.
Note that it does *not* attempt to simpilfy the results so
you end up with very dense (points close together) contour
lines with roughly one segment per pixel crossed.
Also, be aware that the countours are just lines, and because
they just end at edges of he raster or nodata areas, they
aren't easy to form into polygons (if that is your goal).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
