[gdal-dev] MapInfo error handling
Mateusz Loskot mateusz at loskot.net
Fri Sep 19 12:16:23 EDT 2008
Linda Thompson wrote:
> We have quite few customers with problems in their Mapinfo .map files.
> We would like to allow the user to see the .dat information and report
> the problem with their .map file.  I have created a patch for the
> problem that allows me to continue displaying data for the customer and
> allows more flexibility in dealing with the error.
> Do you think this may be a benefit to others using MITAB?
Linda,
Best place to submit patches is GDAL Trac system:
http://trac.osgeo.org/gdal/
Attach patch as a plain text file providing also info about GDAL version
you used to generate your patch.
If you generate patch using SVN copy, you can do it this way:
$ cd /path/to/gdal/trunk
$ svn diff > myfile.patch
And attach myfile.patch to a ticket on Trac.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
