[gdal-dev] small typo in dox for gdal_sieve
Vincent Schut schut at sarvision.nl
Mon Sep 22 02:48:21 EDT 2008
Frank,
a small typo has slipped into the gdal_sieve.dox file:
-4:
     Four connectedness should be used when determining polygons. That
is diagonal pixels are not considered directly connected. This is the
default.
-4:
     Eight connectedness should be used when determining polygons. That
is diagonal pixels are considered directly connected.
obviously should be:
-4:
default.
-8:
(change second -4 into -8)
Cheers,
Vincent.
