[gdal-dev] pct2rgb.py: files >4GB
Tue Sep 23 11:19:40 EDT 2008
Sven Geggus wrote:
> Hello,
> I've got some trouble using pct2rgb.py:
> pct2rgb.py <in>.tif <out>.tif
> ERROR 6: A 81408 pixels x 58368 lines x 3 bands Byte image would be
> larger than 4GB but this is the largest size a TIFF can be.  Creation failed.
> Unfortunately the -of switch does not change this:
> pct2rgb.py -of hfa <in>.tif <out>.img
> Any hint on how to convert the file to rgb in another way?
Sven,
You might want to edit pct2rgb.py and change this line:
if format == 'GTiff':
to:
if format == 'GTiff' or format == 'HFA':
and see if that works.
Alternatively, get a GDAL build with BigTIFF support.  It would appear
you have either an old GDAL or a new GDAL with an old (pre libtiff4)
version of libtiff that does not support bigtiff.
Best regards,
