[gdal-dev] Re: [mapserver-users] can't derive the projection for a
geotiff in Guatemala
John Mitchell
mitchelljj98 at gmail.com
Thu Sep 25 04:10:04 EDT 2008
Frank,
No .aux file was supplied. They just gave us a .tif and a .tfw which were
in the same directory which means gdalinfo was run against both. Based on
the limited information that was supplied the only thing that I can think of
doing at this point is to find all the EPSG codes listed under Guatemala and
running gdalwarp against each and then displaying each within a mapping
application to see if it accurately displays within Guatemala.
John
On Wed, Sep 24, 2008 at 10:43 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> John Mitchell wrote:
>> Hi,
>> I am having difficulty deriving the EPSG code/projection/Coordinate System
>> for a geotiff in Guatemala.
>> Any help would be appreciated.
> John,
> By any chance is there an .aux file with this .tif file? If so, running
> gdalinfo on it might be helpful to get the coordinate system.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Programmer for Rent
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080925/858151e6/attachment.html
