[gdal-dev] caching & spatial indexing of shapefiles?
Mateusz Loskot
mateusz at loskot.net
Thu Sep 25 11:15:19 EDT 2008
Tom Kazimiers wrote:
> Hi there,
> the documentation gave me no real answer to the question if there is
> something like a caching mechanism for feature request. If I request a
> feature, is this read from disk every time or somehow cached?
Tom,
AFAIK, there is no caching mechanism.
I've it on my TODO list to develop a thin wrapper on Shapelib or OGR that
will provide caching support, to minimize disk I/O operations.
> Another thing I could not find out is how I can activate spatial
> indexing for shape files - the documentation says I should execute the
> following SQL command: CREATE SPATIAL INDEX ON tablename [DEPTH N]
> But what is tablename and how do I know if the spatial index is created?
Spatial index is automatically activated if OGR Shapefile driver finds
.qix file for your Shapefile.
Let's say you have Shapefile called roads.shp|.shx|.dbf
Tablename is "roards" - a filename without extension.
Here you can find some real example:
http://mateusz.loskot.net/?p=227
Best regards,
Mateusz Loskot
