[gdal-dev] lib questions
Frank Warmerdam
warmerdam at pobox.com
Sat Sep 27 20:23:16 EDT 2008
On Fri, Sep 26, 2008 at 8:36 AM, Nidel, Mike <mike.nidel at lmco.com> wrote:
> Two quick questions:
> 1. What is libgdalconstjni.so? I've been building and using the JNI
> interfaces and just blindly including this file, but I can't determine
> what this is and whether I need it. Sorry if this is a stupid question,
> I couldn't find the answer in any of the build docs.
Mike,
In theory this contains a bunch of constant defines for GDAL,
stuff like "gdal.GA_ReadOnly". In practice I do not know if this
resolves to actual code in Java or not.
> 2. Is there a reason why on linux the build creates a libgdal.so whereas
> on Windows it's gdalXX.dll, i.e. the version number is inserted in the
> name? I would think you'd want to be consistent across platforms there.
On linux the version handling is done differently by libtool
in order to be consistent with other linux shared libraries.
I think consistency with how things are done on other platforms
is less important than consistency with the general expectations
on the platform in question.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
