[gdal-dev] PAM & nodata values
Matt Klaric
matt at diglib1.cecs.missouri.edu
Tue Sep 30 14:27:01 EDT 2008
I'm attempting to set the nodata value on an NITF image and then
subsequently read this nodata value back out of the image. However this
read fails to find the newly set nodata value. See the attached source
code and an example image. You can see that the nodata value is being
set for (the first band of) the image in the PAM XML file.
Any ideas?
FYI....I'm using version 1.5.2.
Thanks,
Matt Klaric
Type: text/x-c++src
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080930/16765a35/test-0001.bin
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080930/16765a35/mosaic-test-5x5-0001.obj
Type: application/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080930/16765a35/mosaic-test-5x5.ntf.aux-0001.rdf
