[gdal-dev] gdalinfo
James McManus
jmpmcmanus at gmail.com
Wed Apr 1 14:51:38 EDT 2009
When I run gdalinfo on a GRASS binary file it looks for table files, such as
datum.table, in /usr/etc/ instead of /usr/local/grass-6.4.0RC2/etc/ where
they are located.
I have the GRASS and GDAL library path set in /etc/ld.so.conf. I also tried
setting the grass "etc" directory in .bash_profile PATH, but that did not
work. How do I tell gdal to look for tables in the
/usr/local/grass-6.4.ORC2/etc directory?
Thanks
Jim
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090401/c469d469/attachment.html
