[Gdal-dev] mapserver c#mapscript with mapinfo data folder
Tamas Szekeres
szekerest at gmail.com
Thu Apr 2 04:51:18 EDT 2009
meenu,
I assume the layer is read correctly but the map is to be drawn with wrong
extent without specifying that in the mapfile. You should also specify the
projection of the layer and the map to be able to set the extent correctly.
Use ogrinfo.exe to find out the actual extent and projection of the layer
you have.
Best regards,
Tamas
2009/4/2 meenu <meenu.monu at gmail.com>
> hi friend wt u said is right...my problem is how can i add that layer to
> this map file...for example i have one table POI...this layer indicating 4
> files such as POI.DAT,POI.ID,POI.MAP,POI.TAB......how can i add this layer
> to this existing map file...i added the coding is as follows...no error
> found but in map this layer is not showing....in bin directory 2 files is
> thre based on OGR "ogr_OCI.dll" and "ogr_SDE.dll"...is any other files
> required for this OGR set up????
> LAYER
> NAME POI
> TYPE POLYGON
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "C:\Documents and Settings\Administrator\Desktop\julie\Mapserver
> 5.2.1 pjt\Mapserver(5.2.1)-Mapscript\data\POI.TAB"
> STYLEITEM "AUTO"
> CLASS
> NAME "POI"
> END
> END # Layer
> http://n2.nabble.com/mapserver-c-mapscript-with-mapinfo-data-folder-tp2568756p2573619.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090402/685b8e05/attachment.html
