[Gdal-dev] mapserver c#mapscript with mapinfo data folder
meenu
meenu.monu at gmail.com
Thu Apr 2 02:44:25 EDT 2009
hi friend wt u said is right...my problem is how can i add that layer to this map file...for example i have one table POI...this layer indicating 4 files such as POI.DAT,POI.ID,POI.MAP,POI.TAB......how can i add this layer to this existing map file...i added the coding is as follows...no error found but in map this layer is not showing....in bin directory 2 files is thre based on OGR "ogr_OCI.dll" and "ogr_SDE.dll"...is any other files required for this OGR set up????
LAYER
NAME POI
TYPE POLYGON
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "C:\Documents and Settings\Administrator\Desktop\julie\Mapserver 5.2.1 pjt\Mapserver(5.2.1)-Mapscript\data\POI.TAB"
STYLEITEM "AUTO"
CLASS
NAME "POI"
END
END # Layer
View this message in context: http://n2.nabble.com/mapserver-c-mapscript-with-mapinfo-data-folder-tp2568756p2573619.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
