[gdal-dev] Spherical Mercator projects and overviews?
Christopher Schmidt
crschmidt at metacarta.com
Thu Apr 9 11:26:57 EDT 2009
On Thu, Apr 09, 2009 at 11:25:04AM -0500, Stephen Woodbridge wrote:
> >>Hi all,
> >>I have a question regarding imagery in spherical mercator projection
> >>in geotiff images. Do overviews work correctly?
> >>For example, I use EPSG:4326 and build lots of overviews and I can
> >>zoom in and out and pan without a problem. Can I do the same thing
> >>with EPSG:900913 (spherical mercator projection).
> >>I'm working with LandSat imagery over large area and scale ranges.
> >Steve,
> >I can't see any reason that overviews would not work on spherical
> >mercator when they work on images in other coordinate systems. The
> >overview handling is independent of the georeferencing.
> Frank,
> Thanks this is what I was hoping the answer would be.
> My fear was that I would run into something like UTM zones and that you
> can not have one global data set in UTM. So spherical Mercator is
> projects the world into a single x-y plane similar to the way
> geographical is treating the global as stretched onto a single x-y
> plane. This seems reasonable, I just never thought about it before.
Where 'the whole world' in mercator can't actually be 'the whole world';
you have to pick a reasonable north/south cutoff since the tangent of 90
is infinity/undefined.
-- Chris
> Now I get to reproject everything yet again :)
> Thanks,
> -Steve
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Christopher Schmidt
MetaCarta
