[gdal-dev] Problem with OGRCreateCoordinateTransformation
Fri Apr 10 12:48:45 EDT 2009
Reinaldo Escada Chohfi wrote:
> Thanks Frank,
> Yes, I do have the proj.dll is in my path.
> Also, I am looking for the gdalwin32dev160.  Is it available, or we
> don't need it anymore, just the gdalwin32exe160?
> I've been using gdalwin32exe141 & gdalwin32dev141.
Reinaldo,
It appears that a gdalwin32dev160.zip was not produced, but I don't know
why.  The dev kit is needed if you want to build applications against
GDAL.
Best regards,
