[gdal-dev] Problem with OGRCreateCoordinateTransformation
Reinaldo Escada Chohfi
rec at geodesign.com.br
Fri Apr 10 13:11:24 EDT 2009
Frank,
Could you please build the gdalwin32dev160.zip and make it available,
or is someone else that does that?
Thanks,
Reinaldo
At 01:48 PM 4/10/2009, Frank Warmerdam wrote:
>Reinaldo Escada Chohfi wrote:
>>Thanks Frank,
>>Yes, I do have the proj.dll is in my path.
>>Also, I am looking for the gdalwin32dev160. Is it available, or we
>>don't need it anymore, just the gdalwin32exe160?
>>I've been using gdalwin32exe141 & gdalwin32dev141.
>Reinaldo,
>It appears that a gdalwin32dev160.zip was not produced, but I don't know
>why. The dev kit is needed if you want to build applications against
>GDAL.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090410/07c062db/attachment.html
