[gdal-dev] Getting MITAB format out with projection
Reinaldo Escada Chohfi
rec at geodesign.com.br
Sun Apr 12 23:05:40 EDT 2009
Folks,
When I use the following piece of code in a program I can get the
Shape files with the correct projection parameters in a .prj ESRI style file.
const char *pszDriverName = "ESRI Shapefile";
OGRSFDriver *poDriver;
OGRRegisterAll();
OGRSpatialReference oSRS;
oSRS.SetWellKnownGeogCS( "EPSG:4326" );
oSRS.morphToESRI();
oSRS.exportToWkt( &pszWKT );
FILE *prj1;
prj1 = fopen("..\point_out.prj","w");
fprintf(prj1, "%s\n", pszWKT );
However, if I specify
const char *pszDriverName = "MapInfo File";
I don't get the MapInfo files with the projection parameters. I get
the MapInfo files as a non-earth.
Any suggestions are welcomed to help in getting the MapInfo files
with the correct projection information.
Thanks in advance.
Reinaldo
