[gdal-dev] gdal2tiles.py and ProjNatOriginLongGeoKey
Zachary Fisk
zacharyfisk at gmail.com
Mon Apr 13 16:36:42 EDT 2009
I'm trying to merge about 345 tifs NED 10M data for the continental U.S. I
processed the data from ArcInfo Grid to tif (see bottom for the output of
one of the tifs from gdalinfo) using gdal_translate. The error below is
generated from the attempted merge, how I do build GDAL with BigTiff
support? Also I noticed my windows version of the tool supports the
--optfile parameter, but not the linux python script version. Can this
command handle all 345 files on one command? Are there other best practices
methods that I should be aware of, I prefer to process on the linux system
since they, but am open to processing on windows. Whatever works.
*Sample command parameters I'm passing to gdal_merge.py*
gdal_merge.py -o big2.tif -of GTIFF -co BIGTIFF=YES -co TILE=YES -co
COMPRESS=DEFLATE -co PREDICTOR=2 -co BLOCKXSIZE=128 -co BLOCKYSIZE=128
demgrid_101_1.tif demgrid_101_2.tif demgrid_101_3.tif demgrid_102_1.tif
demgrid_102_2.tif demgrid_102_3.tif demgrid_103_1.tif demgrid_103_2.tif
demgrid_103_3.tif demgrid_104_1.tif
Warning 6: BIGTIFF requested, but GDAL built without BigTIFF
enabled libtiff, request ignored.
Segmentation fault
*Output of one of the images passed to the gdal_merge.py from gdalinfo*
gdalinfo demgrid_101_1.tif
Driver: GTiff/GeoTIFF
Files: demgrid_101_1.tif
Size is 32400, 10800
Coordinate System is:
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010042,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]]
Origin = (-120.000000000014793,47.000000000075204)
Pixel Size = (0.000092592592600,-0.000092592592600)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-120.0000000, 47.0000000) (120d 0'0.00"W, 47d 0'0.00"N)
Lower Left (-120.0000000, 46.0000000) (120d 0'0.00"W, 46d 0'0.00"N)
Upper Right (-117.0000000, 47.0000000) (117d 0'0.00"W, 47d 0'0.00"N)
Lower Right (-117.0000000, 46.0000000) (117d 0'0.00"W, 46d 0'0.00"N)
Center (-118.5000000, 46.5000000) (118d30'0.00"W, 46d30'0.00"N)
Band 1 Block=32400x1 Type=Int16, ColorInterp=Gray
NoData Value=-3.4028234663852886e+38
Metadata:
LAYER_TYPE=athematic
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090413/9b8d574a/attachment.html
