[gdal-dev] Is it possible to Buffer using ogr2ogr?
Abhay
abhay.menon at gmail.com
Wed Apr 22 23:31:37 EDT 2009
On Thu, Apr 23, 2009 at 4:07 AM, Roger André <randre at gmail.com> wrote:
> Hi Brent,
> Unfortunately the data is already out of Postgres, so I don't have that
> option anymore. I was hoping there might be some way of invoking a geos
> function in ogr2ogr.
> Thanks though,
> Roger
> On Wed, Apr 22, 2009 at 2:25 PM, <pcreso at pcreso.com> wrote:
>> Yep.
>> In your ogr2ogr query string query try
>> "select buffer(area, nn.nn) as geom from table where...;"
>> PostGIS will buffer it before sending it to GDAL for export to shapefile.
>> Or if you are repeatedly doing this, create a view in PostGIS with the
>> buffer, & select this with GDAL, whichever suits....
>> Brent Wood
>> --- On Thu, 4/23/09, Roger André <randre at gmail.com> wrote:
>> > From: Roger André <randre at gmail.com>
>> > Subject: [gdal-dev] Is it possible to Buffer using ogr2ogr?
>> > To: "gdal-dev" <gdal-dev at lists.osgeo.org>
>> > Date: Thursday, April 23, 2009, 4:59 AM
>> > Hi All,
>> > I'm trying to port some of my existing PostGIS based
>> > workflow to ogr utilities and shapefiles. Is it possible
>> > to buffer a feature that I've selected via the ogr2ogr
>> > "-where" clause? I'd like end up with a
>> > single, buffered feature in a stand-alone shapefile when
>> > I'm done.
>> > Thanks,
>> > Roger
>> > -----Inline Attachment Follows-----
>> > _______________________________________________
>> > gdal-dev mailing list
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Hi Roger,
I donot think there is way around in the ogr2ogr to create buffer that I
know of.
Instead you will need to write a code in C++ or python to do the same.
Rgds.
Abhay.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090423/0663f9cb/attachment-0001.html
