[Gdal-dev] HDF5 problem in VS2008 C# Project
Tamas Szekeres
szekerest at gmail.com
Fri Apr 24 03:43:37 EDT 2009
Sunny,
The HDF5 driver is compiled as a plugin. You have to put the corresponding
dll (gdal_HDF5.dll, gdal_HDF5Image.dll) from the /bin/gdal/plugins
directory to the /gdalplugins subdirectory from where your application is
running.
Alternatively you can set the GDAL_DRIVER_PATH environment variable to point
to the directory where the plugin dll-s are located.
Best regards,
Tamas
2009/4/24 Sunny K <shkwak74 at nate.com>
> Hi all,
> I installed gdal library (release-1500-x64-gdal-1-6-mapserver-5-2.zip),
> but
> have some problems.
> - Windows vista 64bit
> - Visual Studio 2008 Standard.
> I want to process hdf5 file.
> When I executed following command, the error message was printed.
> % gdalinfo hdf5
> % ERROR 1: --format option given with format 'hdf5', but that format not
> recognised. Use the --formats option to get a list of available formats,
> and use the short code (ie. GTiff or HFA) as the format identifier.
> I'd appreciate it if you would tell me some information to solve this
> problem.
> Best regards,
> - sunny
> http://n2.nabble.com/HDF5-problem-in-VS2008-C--Project-tp2689126p2689126.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090424/1aacec20/attachment.html
