[Gdal-dev] HDF5 problem in VS2008 C# Project
Sunny K
shkwak74 at nate.com
Fri Apr 24 06:17:52 EDT 2009
Thanks for your reply.
I set the GDAL_DRIVER_PATH environment variable.
And I can execute gdalinfo.exe of C++ version.
In gdalinfo.exe of C# version, I cannot still execute it.
So, I tried to execute this command using other format (ex. GTIFF, HFA), it
was failed.
"ERROR 4: 'gtiff' does not exxist in the file system, and is not
recignised as a supported dataset name."
Does I need any other settings?
Thanks,
Sunny
Tamas Szekeres wrote:
> Sunny,
> The HDF5 driver is compiled as a plugin. You have to put the corresponding
> dll (gdal_HDF5.dll, gdal_HDF5Image.dll) from the /bin/gdal/plugins
> directory to the /gdalplugins subdirectory from where your application is
> running.
> Alternatively you can set the GDAL_DRIVER_PATH environment variable to
> point
> to the directory where the plugin dll-s are located.
> Best regards,
> Tamas
> 2009/4/24 Sunny K <shkwak74 at nate.com>
>> Hi all,
>> I installed gdal library (release-1500-x64-gdal-1-6-mapserver-5-2.zip),
>> but
>> have some problems.
>> - Windows vista 64bit
>> - Visual Studio 2008 Standard.
>> I want to process hdf5 file.
>> When I executed following command, the error message was printed.
>> % gdalinfo hdf5
>> % ERROR 1: --format option given with format 'hdf5', but that format not
>> recognised. Use the --formats option to get a list of available formats,
>> and use the short code (ie. GTiff or HFA) as the format identifier.
>> I'd appreciate it if you would tell me some information to solve this
>> problem.
>> Best regards,
>> - sunny
>> View this message in context:
>> http://n2.nabble.com/HDF5-problem-in-VS2008-C--Project-tp2689126p2689126.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
View this message in context: http://n2.nabble.com/HDF5-problem-in-VS2008-C--Project-tp2689126p2691639.html
