[gdal-dev] problem with ogr2ogr
Matthew Snape
SnapeM at rpsgroup.com
Mon Apr 27 11:36:51 EDT 2009
Dear List,
I am attempting to use ogr2ogr to append a shapefile to another
shapefile. However, when the -update parameter is included the
incorrect source filename appears to be used.
ogr2ogr -append -update -select meta_type,meta_id,meta_name
"C:/downloadworking/out.shp" "SSSI/sssi.shp"
ERROR 1: Failed to create file .shp file.
ERROR 4: Failed to open Shapefile `C:/downloadworking/out.shp\sssi.shp'.
ERROR 1: Terminating translation prematurely after failed translation of
layer sssi (use -skipfailures to skip errors)
I am using latest FW Tools on XP.
Any ideas?
Thanks.
This e-mail message and any attached file is the property of the sender and is sent in confidence to the addressee only. The contents are not to be disclosed to anyone other than
the addressee. Unauthorised recipients are requested to preserve this confidentiality and to advise the sender immediately of any error in transmission. If you experience difficulty
with opening any attachments to this message, or with sending a reply by email, please telephone on + 44-(0)1235 438151 or fax on + 44-(0)1235 438188.
Any advice contained in this e-mail or any accompanying file attached hereto is for information purposes only. RPS do not take any responsibility for differences between the original
and the transmission copy or any amendments made thereafter. If the addressee requires RPS to be responsible for the contents of this e-mail, RPS will be pleased to issue a signed
hard copy of the document upon request.
RPS Planning and Development Limited, company number: 02947164 (England). Registered office: Centurion Court, 85 Milton Park Abingdon Oxfordshire OX14 4RY.
RPS Group Plc web link: <http://www.rpsgroup.com>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090427/7aae64db/attachment.html
