[gdal-dev] gdal and gras from svn, export problem GTIFF - UINT32
Jamie Adams
jaadfoo at gmail.com
Mon Apr 27 12:23:34 EDT 2009
I had a similar issue with gdal gtiff output awhile back and solved it by
using the internal gdal libtiff. Try using "--with-libtiff=internal" when
compiling gdal.
-Jamie
On Mon, Apr 27, 2009 at 3:57 AM, massimo di stefano <massimodisasha at yahoo.it
> wrote:
> Hi All, i'm having problems using gdal (svn version) from grass6.5
> to export elevation data in format 'GTIF' type 'Byte'
> Tring to export an elevation file from grass (elevation.10m from
> speardfish60 dataset)
> in format "GTIF" type "UINT32"
> $g.region rast=elevation.10m -ap
> $r.out.gdal input=elevation.10m at PERMANENT format=GTiff type=UInt32
> output=/home/sasha/elev.tif
> The grass version compiled using gdal from reposytory works fine,
> while the grass compiled using gdal from svn give me a corrupted file.
> The corrupted file has only 1/2 data ... the boundy box is correct,
> but half of its data is set to 0
> Please tell me if can i provide any log details,
> or maybe instruction to compile gdal to have verbose log
> .... or gdal commandline to test these particolar case-problem
> (other format in r.out.gdal seems to works fine, but i don't tried all)
> i've on my system (sidux64bit) 2 different gdal.
> 1) gdal from the debian gis repository, Version = 1.5.4-3 ;
> 2) gdal-svn, Version = 1.7.0dev, released 2008/11/26)
> building from source grass (6.5 svn) :
> 1- using --with-gdal=/usr/bin/gdal-config
> 2- using --with-gdal=/usr/local/gdal/bin/gdal-config
> These the procedure i'm following to build gdal and grass :
> 1) checkout gdal and grass6.5 from the relaive svn repo.
> 2) download ecw lib, gdal-grass plug-in
> 3) build ecw
> 4) build gdal using :
> ../configure --with-python
> 5) add gdal to ld path :
> thouch /etc/ld.so.conf.d/gdal.conf
> echo "/usr/local/gdal/lib" > /etc/ld.so.conf.d/gdal.conf
> ldconfig
> 6) build grass using :
> gdal-repo :
> ../configure --with-tcltk-includes=/usr/include/tcl8.5/ --with-ffmpeg
> --with-ffmpeg-includes=/usr/include/ffmpeg/ --enable-64bit --with-cxx
> --with-cairo --with-readline --with-sqlite --with-python
> --with-wxwidgets=/usr/bin/wx-config --with-postgres
> --with-postgres-includes=/usr/include/postgresql/ --with-odbc--with-freetype
> --with-freetype-includes=/usr/include/freetype2/ --with-motif
> --with-proj-share=/usr/share/proj/ --enable-largefile
> gdal-svn :
> 7) add grass to ld :
> touch /etc/ld.so.conf.d/grass.conf
> echo "/usr/local/grass-6.5.svn/lib" > /etc/ld.so.conf.d/grass.conf
> 8) build gdal-grass using :
> ../configure --with-gdal=/usr/local/gdal/bin/gdal-config
> --with-grass=/usr/local/grass-6.5.svn/
> 9) compile gdal with grass support :
> cd gdal ; make clean ; make dist clean
> ../configure --with-python --with-grass=/usr/local/grass-6.5.svn/
> Thanks for any help and suggestion
> Massimo Di Stefano
> epifanio on irc.freenode.net /join gfoss
> Chiacchiera con i tuoi amici in tempo reale!
> http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090427/c65cebf9/attachment.html
