[Gdal-dev] gdalwarp, proj4 and Space Oblique Mercator problem
ilumas
anssisamuli at gmail.com
Wed Aug 5 13:49:37 EDT 2009
Dear all,
I'm trying to re-project a USGS Landsat 5 scene with Space Oblique Mercator
projection with the following command:
gdalwarp -s_srs '+proj=lsat +lsat=5 +path=188' -t_srs EPSG:2393 input.tif
output.tif
For some reason this fails:
ERROR 1: Translating source or target SRS failed:
even though my proj -lp lists the lsat projection and the parametrization
seems appropriate to me (see below).
Any idea what's wrong and how could I solve this?
Cheers,
ilumas
--8< from http://download.osgeo.org/proj/proj.4.3.pdf ---8< ----
landsat C E S I
+proj=lsat
+lsat=n
+path=p
This projection (not shown) is for use with landsat
satellite data and is a limited form of the more general
Space Oblique Mercator projection. The landsat satellite
number, n, must be in the range 1–5 and the path
number, p, must be in the ranges 1–251 for n = 1, 2, 3 or
1–233 for n = 3, 4.
tmp> proj -lp |grep lsat
lsat : Space oblique for LANDSAT
tmp> proj
Rel. 4.4.9, 29 Oct 2004
tmp> uname -a
Linux 2.6.13-15.11-smp #2 SMP Fri Jul 28 11:01:31 EEST 2006 x86_64 x86_64
x86_64 GNU/Linux
------- hdr file for the input ------
View this message in context: http://n2.nabble.com/gdalwarp%2C-proj4-and-Space-Oblique-Mercator-problem-tp3393778p3393778.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
