Re: [gdal-dev] reprojection HDF / GCP extraction
Lucena, Ivan
ivan.lucena at pmldnet.com
Mon Aug 10 08:14:39 EDT 2009
Becker,
Please take a look at RFC#4: http://trac.osgeo.org/gdal/wiki/rfc4_geolocate
Regards,
Ivan
> -------Original Message-------
> From: Becker, Thomas <thob at dmu.dk>
> Subject: [gdal-dev] reprojection HDF / GCP extraction
> Sent: Aug 10 '09 07:00
> Hi all,
> I have a couple NOAA-15 images as HDF-EOS files which I would like to reproject to WGS84. The data carry a
subgroup called 'Geolocation Fields' holding latitude and longitude for each pixel in separated arrays. Reading the files
with gdalinfo leads to the output at the end of this posting.
> Out of the HDF-EOS format I would like to create a correct georeferenced image (GTIF). One which will not look
like a swath scanned image, but a skewed and correctly referenced one.
> Using gdalwarp leads to the message: There is no affine transformation and no GCPs.
> Since the coordinates for the centre of each pixel are stored in the before mentioned arrays, is there a way to
extract GCPs out of the data.
> Thanks for your help.
> Best regards,
> Thomas
> gdalinfo output:
> Driver: HDF4/Hierarchical Data Format Release 4
> Files: amsua15_2000.034_08964_0104_0258_GC.eos
> Size is 512, 512
> Coordinate System is `'
> Metadata:
> HDFEOSVersion=HDFEOS_V2.4
> Subdatasets:
> SUBDATASET_1_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:23800.37 MHz
> SUBDATASET_1_DESC=[851x30] 23800.37 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_2_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:31400.42 MHz
> SUBDATASET_2_DESC=[851x30] 31400.42 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_3_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:50299.91 MHz
> SUBDATASET_3_DESC=[851x30] 50299.91 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_4_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:52799.39 MHz
> SUBDATASET_4_DESC=[851x30] 52799.39 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_5_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:53595.41 +- 115 MHz
> SUBDATASET_5_DESC=[851x30] 53595.41 +- 115 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_6_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:54399.53 MHz
> SUBDATASET_6_DESC=[851x30] 54399.53 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_7_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:54940.64 MHz
> SUBDATASET_7_DESC=[851x30] 54940.64 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_8_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:55498.70 MHz
> SUBDATASET_8_DESC=[851x30] 55498.70 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_9_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:57290.33 MHz
> SUBDATASET_9_DESC=[851x30] 57290.33 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_10_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:57290.33 +- 217 MHz
> SUBDATASET_10_DESC=[851x30] 57290.33 +- 217 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_11_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:57290.33 +- 322.2 +- 48 MHz
> SUBDATASET_11_DESC=[851x30] 57290.33 +- 322.2 +- 48 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_12_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:57290.33 +- 322.2 +- 22 MHz
> SUBDATASET_12_DESC=[851x30] 57290.33 +- 322.2 +- 22 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_13_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:57290.33 +- 322.2 +- 10 MHz
> SUBDATASET_13_DESC=[851x30] 57290.33 +- 322.2 +- 10 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_14_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:57290.33 +- 322.2 +- 4.5 MHz
> SUBDATASET_14_DESC=[851x30] 57290.33 +- 322.2 +- 4.5 MHz Orbit 8964 (32-bit floating-point)
> SUBDATASET_15_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit
8964:88997.00 MHz
> SUBDATASET_15_DESC=[851x30] 88997.00 MHz Orbit 8964 (32-bit floating-point)
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 512.0)
> Upper Right ( 512.0, 0.0)
> Lower Right ( 512.0, 512.0)
> Center ( 256.0, 256.0)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
