[gdal-dev] reprojection HDF / GCP extraction
Becker, Thomas
thob at dmu.dk
Mon Aug 10 09:05:29 EDT 2009
Hello Ivan,
thanks for the hint. Now is this how GDAL already works? Because this track is meant for comments. At least in my data which are from 2000 I can not see any metadata of that kind. After reading the trac I am puzzled. Also in the output of gdalinfo only the subdatset of 'Data Fields' is mentioned and not the subdataset of 'Geolocation Fields'. I can not realy see which band represent latitude and longitude.
If I just don't understand the trac maybe you can tell me how a command to GDAL, based on the gdalinfo output would look like to get the job done.
Regards,
Thomas
-----Original Message-----
From: Lucena, Ivan [mailto:ivan.lucena at pmldnet.com]
Sent: Monday, August 10, 2009 2:15 PM
To: Becker, Thomas; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] reprojection HDF / GCP extraction
Becker,
Please take a look at RFC#4: http://trac.osgeo.org/gdal/wiki/rfc4_geolocate
Regards,
Ivan
