RE: [gdal-dev] reprojection HDF / GCP extraction
Lucena, Ivan ivan.lucena at pmldnet.com
Mon Aug 10 09:37:17 EDT 2009
Becker,
I afraid I don't have much to add to what is in the RFC#4. You can search on the discussion list archives for more
information or wait for the sun to weak up the experts.
Regards,
Ivan
>  -------Original Message-------
>  From: Becker, Thomas <thob at dmu.dk>
>  Subject: RE: [gdal-dev] reprojection HDF / GCP extraction
>  Sent: Aug 10 '09 08:05
>  Hello Ivan,
>  thanks for the hint. Now is this how GDAL already works? Because this track is meant for comments. At least in
my data which are from 2000 I can not see any metadata of that kind. After reading the trac I am puzzled. Also in
the output of gdalinfo only the subdatset of 'Data Fields' is mentioned and not the subdataset of 'Geolocation
Fields'. I can not realy see which band represent latitude and longitude.
>  If I just don't understand the trac maybe you can tell me how a command to GDAL, based on the gdalinfo
output would look like to get the job done.
>  Regards,
>  Thomas
>  From: Lucena, Ivan [mailto:ivan.lucena at pmldnet.com]
>  Sent: Monday, August 10, 2009 2:15 PM
>  To: Becker, Thomas; gdal-dev at lists.osgeo.org
>  Subject: Re: [gdal-dev] reprojection HDF / GCP extraction
>  Becker,
>  Please take a look at RFC#4: http://trac.osgeo.org/gdal/wiki/rfc4_geolocate
>  Regards,
>  Ivan
