[gdal-dev] Re: C# Nad27 to WGS 84
Tomas R
monshi at home.se
Thu Aug 20 16:13:50 EDT 2009
Installed .Net2 SDK on my Vista machine and compiled it via that
installation and it worked. But should it not be doable on a .net3.5
installation? From GUI editor (VSE 2008) it is, should also be via the
command line.
Yours
Tomas
Tamas Szekeres skrev:
> 2009/8/18 Tomas R <monshi at home.se <mailto:monshi at home.se>>
> Ah, thanks. Been away some time from the list and no email
> regarding this answer. Will try it but am happy with the binaries
> I currently have.
> Another Q...
> On my Vista machine when I compile GDAL/Swig-links it is
> compiled for the .Net 3.5 platform. Would like to target .Net 2
> instead. How? Am investigating myself but no luck so far.
> Must I install .Net 2 SDK on my Vista? In the GUI there is no
> problem targeting .Net 2 but on the commandline? I currently open
> up, set up, the environment using the setenv.cmd in the folder
> C:\Program Files\Microsoft SDKs\Windows\v6.1\Bin
> Compiles fine, but to .Net 3.5.
> An environment setting? or?
> I don't see any any framework preference in the default compilation,
> it depends on which version of mscorlib is available at compile time.
> This should be .net framework 2.0 by default, so make sure this
> framewok version have been installed side by side on the development
> machine.
> Best regards,
> Tamas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
