[gdal-dev] GDAL Erdas LAN/GIS driver
Roger Bivand
Roger.Bivand at nhh.no
Fri Aug 21 12:58:11 EDT 2009
On Fri, 21 Aug 2009, Roger Bivand wrote:
> On Fri, 21 Aug 2009, Frank Warmerdam wrote:
>> Roger Bivand wrote:
>>> Hi,
>>> The code for the LAN/GIS driver uses GDT_Int16 for Pixel type 2, rather
>>> than GDT_UInt16. Is this justified? A user of rgdal has a case of unsigned
>>> 16-bit data stored by "a forest landscape model", being treated by the
>>> driver as signed. The header does not seem to have a signed/unsigned flag.
>>> Is this a problem of ambiguity in use of a (closed?) specification, or
>>> should the driver be using GDT_UInt16?
>>> I'm asking on the list first, because this may be ambiguity, not a bug.
>> Roger,
>> The only specification information I have on the format does not indicate
>> whether 16bit values should be treated as signed or unsigned. If you are
>> confident that it should be treated as unsigned file a ticket and we will
>> fix it - hopefully this won't just break it for someone else!
> Frank,
> Thanks, I'm waiting to receive the affected file. I'll let you know when I've
> got it.
(reverting to list)
Correction, the user reported that:
> Apparently, gdalinfo retrieves the correct min, max, and statistics,
> despite the use of GDT_Int16.
on his Windows platform. The different GDAL versions ought to explain why
his gdalinfo says Int16 but gives statistics from UInt16.
He has:
>From FWTools:
gdalinfo --version
GDAL 1.7.0dev, FWTools 2.4.2 released 2009/06/24
C:\Program Files\FWTools2.4.2>gdalinfo stand_bm.gis
Driver: LAN/Erdas .LAN/.GIS
Files: c:\landis\harvest_problem\FTT-N_MinT-N\stand_bm.gis
c:\landis\harvest_problem\FTT-N_MinT-N\stand_bm.gsw
Size is 1758, 839
Coordinate System is:
LOCAL_CS["Unknown",
UNIT["Meter",1]]
Origin = (33773.261718750000000,945478.062500000000000)
Pixel Size = (100.000000000000000,-100.000000000000000)
Corner Coordinates:
Upper Left ( 33773.262, 945478.063)
Lower Left ( 33773.262, 861578.063)
Upper Right ( 209573.262, 945478.063)
Lower Right ( 209573.262, 861578.063)
Center ( 121673.262, 903528.063)
Band 1 Block=1758x1 Type=Int16, ColorInterp=Undefined
Min=0.000 Max=48499.000
Minimum=0.000, Maximum=48499.000, Mean=12833.830, StdDev=13635.800
Metadata:
STATISTICS_MINIMUM=0
STATISTICS_MAXIMUM=48499
STATISTICS_MEAN=12833.830260712
STATISTICS_MEDIAN=8.7254821994872e-239
STATISTICS_MODE=3.9864100424366e-293
STATISTICS_STDDEV=13635.800289332
LAYER_TYPE=thematic
rgdal_0.6-12
> getGDALVersionInfo()
[1] "GDAL 1.6.1, released 2009/05/11"
For me on x86_64, GDALinfo() in rgdal and 1.6.2 gdalinfo -stats agree.
$ gdalinfo -stats stand_bm.gis
Files: stand_bm.gis
Size is 1758, 839
LOCAL_CS["Unknown",
UNIT["Meter",1]]
Corner Coordinates:
Upper Left ( 33773.262, 945478.062)
Lower Left ( 33773.262, 861578.062)
Upper Right ( 209573.262, 945478.062)
Lower Right ( 209573.262, 861578.062)
Center ( 121673.262, 903528.062)
Minimum=-32140.000, Maximum=29620.000, Mean=8315.507, StdDev=13186.107
Metadata:
STATISTICS_MINIMUM=-32140
STATISTICS_MAXIMUM=29620
STATISTICS_MEAN=8315.5065072863
STATISTICS_STDDEV=13186.10731815
On the trunk, GDT_Int16 is used too, so how does gdalinfo detect that it
is actually UInt16?
Roger
> Best wishes,
> Roger
>> Best regards,
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
