[gdal-dev] GDAL Erdas LAN/GIS driver
Mon Aug 24 17:39:36 EDT 2009
Roger Bivand wrote:
> (reverting to list)
> Correction, the user reported that:
>> Apparently, gdalinfo retrieves the correct min, max, and statistics,
>> despite the use of GDT_Int16.
> on his Windows platform. The different GDAL versions ought to explain
> why his gdalinfo says Int16 but gives statistics from UInt16.
> On the trunk, GDT_Int16 is used too, so how does gdalinfo detect that it
> is actually UInt16?
Roger,
I believe the min/max is actually being read from the file header in trunk
and is handled without regard to the actual imagery or it's type.
I skimmed the changelog for this driver and I didn't notice any obvious
changes in metadata / statistics handling so I'm surprised at this result.
Best regards,
