[gdal-dev] Does GDAL support ArcInfo Binary Grids with multiple
bands?
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 27 17:50:45 EDT 2009
Jason Roberts wrote:
> Is the GDAL ArcInfo Binary Grid (AIG) driver intended to support AIGs
> with multiple bands? I have a 5-band AIG for which the Python gdal
> bindings for GDAL 1.6.0 report "`C:\Temp\ccomp2' not recognised as a
> supported file format." ArcGIS 9.3.1 reports that the "format" of it is
> "GRID Stack 7.x". It was created using standard ArcGIS tools.
> If this is not supported, I can work around the problem. I just would
> like to know the intent of the GDAL team.
Jason,
I'd like to investigate the dataset if possible, to try and understand
why it isn't supported and if it could be easily enabled.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
