[Gdal-dev] PROJ.4 EPSG:28992
TomvanTilburg
tom.van.tilburg at gmail.com
Wed Dec 2 09:25:05 EST 2009
Hi Even,
Thanks for replying.
I don't think GDAL installation is the problem, since trying the same code
with different geom works fine.
But I just ran it in the DOS box and got a bit more descriptives:
WKT:POINT(127576.476563 481237.375)
POINT (127576.476563 481237.375)
ERROR 6: Failed to initialize PROJ.4 with `+proj=sterea
+lat_0=52.15616055555555 +lon_0=5.387638888888889 +k=0.9999079 +x_0=0 +y_0=0
+ellps=bessel +units=m +no_defs '.
unknown projection id
Seems like the projection id (this is the EPSG code?) is the culprit.
Any new ideas?
best regards,
Tom
Even Rouault wrote:
> A few points to check that come to mind :
> * Did you check that the proj.dll can be loaded by GDAL ? Check an error
> message about it
> * Is the GDAL_DATA environment variable correctly set ?
> * If testepsg.exe is compiled (nmake /f makefile.vc testepsg.exe in apps
> directory should do), try testepsg EPSG:28992
View this message in context: http://n2.nabble.com/PROJ-4-EPSG-28992-tp2033665p4100011.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
